Activity Forums Adobe Premiere Pro Premiere Pro CS3 preview window NOT ACCURATE for 720
  • Bro. Steve winter
    July 13, 2010 at 6:54 pm
    OK, here are a couple of images that might make it clearer what I am experiencing.
    First see what I am seeing in Premiere Pro and then see what is on the actual video. I have to simply guess where to put things near the edges.
    Then here is what the actual video is showing. Note the position of the feet. Notice the distance from my head to the overhang behind it how the image shifts a huge amount
    I am having to fly blind for the whole outside edge of the video and just GUESS where things will appear.
    Thanks to everyone pitching in!
    Bro. Winter
    https://www.winterband.com
    All original Christian music videos
  • Bro. Steve winter
    July 13, 2010 at 10:34 pm
    I am using DV import by connecting the camera by firewire. I manually scale the different “Green screen” videos to the size and location that I want them. The problem is that my workspace inside of Premiere Pro is not giving me an accurate representation of what the video will look like.
    I tried the scale to frame size and that just made the background graphic way too small to use.
    Regards,
    Bro. Winter
  • Brian Louis
    July 14, 2010 at 5:06 am
    I don’t know what you are up to but video is identified by its vertical resolution, DV is ntsc 480i, pal 576i or xxxp, HD is 1080, i or p or 720p, if you are editing to make a ntsc DVD the final matrix will be 720×480(480x) so everything you add to that matrix should be eventually to scaled 720×480 unless its a PIP or split screens or montages, if you not going to make a DVD but maybe for the net or computer you will have to scale the output to resolution you are going to use.
  • Bro. Steve winter
    July 14, 2010 at 5:21 am
    When I start a video I am presented with only 4 presets under DV-NTSC. I used to (for years actually) pick Standard 48Hz but decided to switch to Widescreen 48Hz and that is when these problems started.
    I use MiniDV on the cameras which have a firewire connection and can be controlled by Premiere Pro.
    I believe there is a defect in Premiere Pro CS3
    Regards,
    Bro. Winter
  • Brian Louis
    July 16, 2010 at 5:22 pm
    <> I used to (for years actually) pick Standard 48Hz but decided to switch to Widescreen 48Hz and that is when these problems started<>
    Question? what camcorders are you using? are you shooting in 4:3 and editing in 16:9?
  • Bro. Steve winter
    July 17, 2010 at 12:43 am
    I am using Canon ZR900 for some of the shots, but that should not affect the background graphics or the position of videos.
    Bro. Winter
Page 2 of 2
