Activity › Forums › Adobe Premiere Pro › premiere pro cs3 crashes physical memory high
  • premiere pro cs3 crashes physical memory high
    Posted by Tim Gannon on January 19, 2010 at 4:43 pm
    hi,
    hope someone can help.
    my premire pro cs3 keeps crashing especially after i use an colour effect or manuel sound reducer/increaser.
    the device manager at the time says the program is using over 80 per cent physical memory.
    my stats are: athlon 64 x2 3800+ 2.00 ghz
    2046 mb
    vista 32 bit
    premiere pro seems to use 700000k qhich seems a massive lot
    can anyone help
    do i need a greater memory store?
    btw i have defraged in the last to no avail.
    Vince Becquiot replied 16 years, 8 months ago 2 Members · 1 Reply
  • Vince Becquiot
    January 19, 2010 at 5:57 pm
    Yes, you will likely need more RAM. I would also recommend that you upgrade to Win 7 64, as it will not only use less RAM than Vista to run, but will also allow you to use more than 3 Gigs of RAM, which is all you can use in the 32 Bit version of Vista.
    For Premiere CS3, 4 to 6 Gigs of RAM should be the bare minimum.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
