Activity › Forums › Adobe Premiere Pro › premiere pro CS3
  • premiere pro CS3
    Posted by Fiona Wilkinson on September 29, 2009 at 8:25 pm
    Hi Guys. I’m trying to anchor individual graphics to a still photo that has a pan and zoom applied to it. Basically, the image is zoomed in and then it pans up. As it pans, I have other graphics dissolve into the image at particular times and I would like them to pan up as the image does. THEN as the image zooms out, I would like these graphics to zoom out and scale down but stay at the appropriate place. I finally got this working correctly, BUT the issue is, is that as the smaller graphics pan and zoom, they FLICKER. I’ve tried many things, but cannot get this to stop.
    The graphics are rasterized text from PSD files. I’ve tried creating Titles in PPro but I can’t get the text to synch with the image as it zooms and pans.
    Any ideas? Many thanks.
    Jeff Brown replied 16 years, 12 months ago 3 Members · 3 Replies
  • Alex Udell
    September 29, 2009 at 11:45 pm
    Honestly….
    This could be accomplished with better quality in After Effects using a nested composite.
    Do you have access to AE?
    Alex
  • Fiona Wilkinson
    September 30, 2009 at 1:12 pm
    Thanks Alex – I know it may be better with AE. Unfortunately, I don’t have AE at the moment. I’ve tried multiple things and flickering continues and it’s a bit maddening. I just flattened the image so the text and photo are one, took it into Premiere and it’s still flickering. I’m at my wits end with this one.
    Fiona
  • Jeff Brown
    September 30, 2009 at 6:08 pm
    Can you post a still frame of the problem?
    -Jeff
