Activity › Forums › Adobe Premiere Pro › Premiere Pro CS3
  • Premiere Pro CS3
    Posted by David Thomas on August 11, 2009 at 1:27 pm
    I have 3 computers running Adobe Premiere Pro CS3, Video1, Video2, and Video3. Video1 and Video2 work fine, but when I try to view/edit a project created on either Video1 or Video2 using Video3 any MOV files say “Media Off-Line”. It does not matter if it is saved local or on a network drive. The only way I can get it to work is if I remove the MOV file from the bin and re import it. By doing that I lose all my edits I previously made. Any suggestions?
    Sreejith Antony k replied 17 years, 1 month ago 3 Members · 5 Replies
  • Sreejith Antony k
    August 12, 2009 at 10:57 am
    Hey u don’t worry buddy,
    Shall i ask u one thing? when u open project in the video3 u got red screen showing media offline ? (usually i’m receiving this type of msgs)
    If yes the u just try this method
    select all ur layers in the timeline by Ctrl+A then move fwd a bit
    thats it .
    Sreejith Antony K
    sreejithantony@gmail.com
    http://www.zfxstudio.com
    +91-9995126448
  • Jon Barrie
    August 13, 2009 at 10:07 am
    You don’t need to delete the file from the project, just right click it and select relink… find the file and you won’t lose any of the edits you made.
    If this file is on an external drive its possible that the drive letter is changing causing the file’s location to be unseen.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • David Thomas
    August 13, 2009 at 1:22 pm
    Nope, doesn’t work. I’ve moved it all around the time line. I created a new project and put only one MOV in there and it still does the same thing. Seems like anything I try it is not fixing it.
  • David Thomas
    August 13, 2009 at 1:26 pm
    Tried that and it didn’t work. I’ve had several people look at it and no one has been able to fix it. All the video editors and everyone from the system administration team. I’ve tried reinstalling Premiere, Quicktime, and a whole bunch of other codecs.
  • Sreejith Antony k
    August 13, 2009 at 4:43 pm
    plz chk ur hard disk before u go for a full format and re instalation
    Sreejith Antony K
    +91-9995126448
