Activity Forums Adobe Premiere Pro premiere pro CS 5.5 question. How do I change source monitor TC to 59.94 drop frame TC?
  • premiere pro CS 5.5 question. How do I change source monitor TC to 59.94 drop frame TC?
    Posted by Andrew Hays on December 23, 2012 at 11:23 pm
    I’m working on a project from FCPX in which the audio is being mixed in premiere pro CS 5.5. THe timecode base for the clips is 59.94, however when I type my timecode for in and out in the source monitor, it changes the timecode on me. How do I change the source monitor’s timecode from 29.97 to 59.94 in CS5.5?
    Jason Brown replied 12 years ago 4 Members · 5 Replies
  • Angelo Lorenzo
    December 24, 2012 at 10:03 am
    It’s a very buried, strangely labeled setting.
    Edit > Preferences > Media > A setting called “Indeterminate Media Timebase”
    Audio files, if they aren’t broadcast wave files with embedded timecode (and even that is a calculation based on samples since midnight) then Premiere uses the timecode base for this setting since audio is sample based, not frame based.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Ann Bens
    December 24, 2012 at 10:17 pm
    Correct me if I am wrong but I alway thought Indeterminate Media Timebase specifies the framerate for imported still-image sequences.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Angelo Lorenzo
    December 26, 2012 at 5:38 am
    Ann, I would assume it does exactly what the setting suggests: places a time base on an indeterminate file. Image sequences would be part of that but audio as well; audio uses audio samples as its true fractional measurement of time, so unless it contains additional timecode info (like broadcast WAV files) then Premiere is interpreting it in a more video-friendly way.
    I did test what happens when changing that setting and it will change how timecode is displayed in the source monitor.
    Kind of interesting to know.
    Angelo Lorenzo
  • Ann Bens
    December 27, 2012 at 10:21 am
    OK thanks.
  • Jason Brown
    September 9, 2014 at 6:33 am
    OMG…I know this thread is old, but this completely helped me and I wanted to thank you.
    Edirol R4 pro recorded TC at 23.976, came into premier at 29.97…this fixed my problem.
