Activity › Forums › Adobe Premiere Pro › Premiere Pro Crashes since recent CC update
  • Premiere Pro Crashes since recent CC update
    Posted by James Kendrick on October 15, 2014 at 3:45 pm
    Machine specs: HP Z820 – xeon e5-2690 48gb ram quadro k5000.
    Since the recent updates & complete wipe of the system & fresh install, Premiere pro CC crashes regularly without any pattern. Using MXF files while editing if that helps-i did read a thread about that – but it was old. This is a new problem. The event viewer information:
    Faulting application name: Adobe Premiere Pro.exe, version: 8.1.0.81, time stamp: 0x5426694c
    Faulting module name: mc_dec_mp2v.dll_unloaded, version: 0.0.0.0, time stamp: 0x53f72b76
    Exception code: 0xc0000005
    Fault offset: 0x000007feea381a30
    Faulting process id: 0x2168
    Faulting application start time: 0x01cfe7cdce8c2c97
    Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CC 2014\Adobe Premiere Pro.exe
    Faulting module path: mc_dec_mp2v.dll
    Report Id: ba9aeb2b-53c1-11e4-b3dd-24be05e2e6a2
    Audition has also started crashing as well. Info:
    Faulting application name: Adobe Audition CC.exe, version: 7.1.0.119, time stamp: 0x5421531b
    Faulting module name: MSVCR110.dll, version: 11.0.51106.1, time stamp: 0x5098826e
    Fault offset: 0x000000000003c780
    Faulting process id: 0x249c
    Faulting application start time: 0x01cfe7ebfe3ea9e0
    Faulting application path: C:\Program Files\Adobe\Adobe Audition CC 2014\Adobe Audition CC.exe
    Faulting module path: C:\Windows\system32\MSVCR110.dll
    Report Id: 4d975a0f-53e3-11e4-b3dd-24be05e2e6a2
    Any Ideas?
    James Kendrick replied 11 years, 11 months ago 2 Members · 2 Replies
  • Kevin Monahan
    October 15, 2014 at 7:21 pm
    Hi James,
    See if this post helps you: https://forums.adobe.com/thread/1587549
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • James Kendrick
    October 15, 2014 at 8:19 pm
    Tried it, as well as replacing the crashing file in windows system 32. In the interim, a new update to after effects came in to “fix bugs.” There were embedded AE comps in each of the jobs that were crashing. So far so good. The jobs I’m working on today are fairly lightweight compared to the ones I worked on last week when the thing crashed 18 times in one day. We’ll see. Thanks
    Jim
