Activity Forums Adobe Premiere Pro Premiere Pro – Compiling Showreel
  • Premiere Pro – Compiling Showreel
    Posted by Gavin Williams on August 4, 2013 at 6:43 pm
    Hi
    I have 7 or 8 premiere pro edited projects I want to compile as a showreel – what’s the best way to get these projects together in one timeline?
    Also a couple are at 24 FPS while the rest are 25 FPS – what’s a good way around this??
    Thanks – any help would be great!
    Gav
    Ivan Myles replied 13 years ago 2 Members · 3 Replies
  • Ivan Myles
    August 4, 2013 at 7:36 pm
    If the projects aren’t overly complex import each file into a new project. You can drag sequences from the Project panel into a new timeline and Premiere Pro will treat the sequences as though they were clips of footage.
    If the projects are relatively complex and you don’t want to bog down your system, export intermediate files from each project (in entirety or just the clips you want to use). The preferred choice of codec would be a 10-bit, all I-frame, 4:2:2 or 4:4:4 format such as ProRes, DNxHD, AVC-Intra, Cineform, V210, or DPX+WAV.
    The difference between 24 and 25fps should not be noticeable; just insert the footage onto a timeline and Premiere will automatically make the required adjustments. Choose the frame rate that makes most sense for your audience, or whichever rate comprises the majority of your footage. Worst case, make two reels — one 24fps and one 25fps.
  • Gavin Williams
    August 4, 2013 at 8:23 pm
    Hey Ivan
    Thanks for the help – when I import a Premiere project into a new premiere project and then drag the sequence into the timeline it opens it up as that sequence with all the clips in it rather than just a clip I can can and place??
  • Ivan Myles
    August 4, 2013 at 8:29 pm
    What version of Premiere are you using? In CS6 a sequence will appear as a green clip when inserted onto a new timeline. Double-clicking the sequence/clip will open the nested timeline with the individual source footage clips.
