Activity Forums Adobe Premiere Pro Premiere Pro Cloud GTX 680 Card for Mac
  • Premiere Pro Cloud GTX 680 Card for Mac
    Posted by Mike Rodriguez on July 1, 2013 at 3:52 am
    I have installed GTX 680 for Mac card on 12 Core Mac Pro running 10.8.4(Removed the ATI 5770 card). Went into PPC and it did not see the cuda option for rendering in project settings. Went to the Mac system and there is no driver installed for this card although the card is recognized by the system. Went to Nvida site and could not find a current driver. My IMAC running same OS and a ATI card has Cuda driver 5.0.61 driver installed , Are these drivers universal and will this work on my Mac Pro? Is there another separate driver?
    Mike
    Robin replied 12 years, 9 months ago 6 Members · 5 Replies
  • Greg Jones
    July 1, 2013 at 5:57 pm
    If you go to nvidia support site, look for the k5000 Mac drivers. They work with the gtx680 Mac.
    Greg
  • Bob Zelin
    July 4, 2013 at 4:35 pm
    If you contact me, I can help you with the GTX 680
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Jason Van patten
    July 10, 2013 at 5:50 pm
    [mike Rodriguez] “Are these drivers universal and will this work on my Mac Pro? Is there another separate driver?”
    You didn’t mention whether or not you had the CUDA drivers installed on your Mac Pro. If you don’t have them installed, you’ll need them. They’re the same drivers you have on our iMac. Get them here.
    You can continue to use the stock Apple-provided nVidia drivers for your card, or you can use nVidia’s if you like. Grab them here.
  • Bruce Feagle
    July 29, 2013 at 2:10 am
    Hi Bob,
    I’m having a similar problem. I installed the CUDA driver v5 and the web driver. Premiere now sees the GTX680 as GPU and OpenCL. Is one of these better than the other? But, AfterEffects still only sees the card via OpenCL. Does this matter? Thanks for the help.
    Bruce
    Bruce Feagle
  • Robin
    July 29, 2013 at 2:54 am
    Hi Mike,
    You can enable PProCC to use CUDA even if the card is not supported under Project Settings. FYI, I had no problems with my card immediately after I put in the card into my MacPro.
    -Robin
