Activity Forums Adobe Premiere Pro Premiere Pro CC won’t let me select a scratch disk
  • Premiere Pro CC won’t let me select a scratch disk
    Posted by Alex Neuman on November 14, 2013 at 11:21 pm
    I am running Premiere Pro CC latest update with OS X Mavericks (it used to happen with Lion also) on a Mac Pro 15″. Every time I connect a USB 3 drive and try to select it as a scratch disk it tells me it;s protected and can’t use it so it will use my documents folder. I know the disk is read & write because it says so when I get the info (Command I) on the mac.
    Any tips would be greatly appreciated it!
    AN
    Alex N.
    Alex Neuman replied 12 years, 9 months ago 3 Members · 3 Replies
  • Lance Bachelder
    November 15, 2013 at 2:55 am
    Use Get Info on the drive – make sure read/write is active
    Lance Bachelder
    Writer, Editor, Director
    Downtown Long Beach, California
    https://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1
  • Phil Yunker
    November 17, 2013 at 8:35 pm
    I came across this post a while back and it has helped me with this issue:
    1.) First make sure your scratch disk is writable. Right click on the external drive desktop icon. Under the drop down menu choose Get Info. At the bottom unlock the spotlight screen. You will be prompted to enter your password. Back in the menu next to your Name and under Priveldge chooseRead & Write. Lock and close.
    2.) Open Premiere Pro CS 5.5 or CS 6. Click on New Project. In General, under location select your external drive under Browse. Next Name your project. At this time, don’t worry about the Scratch Disk settings. You will probably get a “scratch disk is write protected or unavailable” error or something similar.
    3.) For the moment click through the chosen Premiere Pro disk location on your computer and open your new project. In Premiere Pro at the top of the screen open Preferences. Under Preferences choose Media. Under Media Cache Files choose Browse on
    your external drive and select a location for the folder. Under Media Cache Database select Clean.Next select Browse and select a location for the folder. Select Ok at the bottom of the screen and it will close.
    4.) Next at the top of the screen select Project. Under the Project Settings in the drop down menu choose Scratch Disks. From here there are two ways to make the adjustment. One way is to select Project from the drop down menu. This should point to where your project file is being stored on the external hard drive. The second is to select the Browse button and find a location for each file on your external drive. Select Ok at the bottom and the screen will close.
    It may take a little work but your scratch disk is now setup on your external drive. If you change drives at any time, you will have to go through the whole process all over again.
    PHIL YUNKER
    Vanguard Media & Entertainment
    http://www.philyunker.com
    http://www.linkedin.com/in/philyunker
  • Alex Neuman
    November 19, 2013 at 8:05 pm
    That solved it!! THANKS!!!
    AN
    Alex N.
