Activity Forums Adobe Premiere Pro Premiere Pro CC will not import .MOV files
  • Premiere Pro CC will not import .MOV files
    Posted by Christopher May on June 12, 2014 at 1:59 pm
    Having issues with Premiere Pro CC, I cannot import .MOV files created with my Canon 6D.
    If I try to import the files, I get a very generic “File format not supported” error msg.
    This is a new install of Premiere CC on a new computer. I was able to import them using Premiere Pro CC on the old computer.
    Quicktime will play these files fine on my new computer.
    Premiere Pro CS6 will import these files on the new computer.
    Premiere Pro CC would open them fine on my old computer.
    I’m not even sure where to start. Any help would be appreciated.
    Here are my system details:
    • OSX 10.9.3
    • new Mac Pro
    • 3Ghz 8-Core Xeon E5
    • 64 GB RAM
    • Files are on external G-Tech Thunderbolt drive.
    Jane Kong replied 11 years, 8 months ago 10 Members · 11 Replies
  • 11 Replies
  • John Pale
    June 12, 2014 at 3:13 pm
    As a troubleshooting step, copy one of the files to your desktop and try to Import it. do you get the same error?
  • Chris Borjis
    June 12, 2014 at 4:38 pm
    [Christopher May] “OSX 10.9.3”
    there are a number of issues with 10.9.3, I wonder
    if that is one of them.
    apple is reportedly working on a 10.9.4 to address the
    problems.
  • Kevin Monahan
    June 12, 2014 at 6:24 pm
    Hi Christopher,
    You probably need to reactivate Premiere Pro. See this FAQ: https://forums.adobe.com/message/6416340#6416340
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Christopher May
    June 12, 2014 at 6:41 pm
    I just re-installed Premiere and all is working.
  • Kevin Monahan
    June 12, 2014 at 7:25 pm
    Cool. Thanks for the report.
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Greg Leslie
    June 13, 2014 at 3:09 am
    The FAQ you link to (and the document IT links to) both date to 2012 and are CS6-specific. I assume the same problem (and its solution) exists in CC?
    Greg Leslie
    Tulsa
  • Tim Kolb
    June 14, 2014 at 5:49 pm
    If you run into the issue again, try opening an existing project. If it comes up with an unsupported sequence setting, it’s a good bet that the software has reverted to trial mode.
    This can happen if you use external USB drives and swap them frequently.
    Adobe has a fix:
    https://helpx.adobe.com/creative-cloud/kb/unable-login-creative-cloud-248.html
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Hamish Storey
    September 27, 2014 at 5:01 pm
    Try downloading QuickTime if not already installed – worked for me. (I had also re-installed PP CC & restarted).
    Hope that helps.
  • Juliet Zhu
    November 20, 2014 at 2:05 am
    rename the file and save it to some other location and then import it or import the clip directly from the camera card using media browser.
    https://format-changes.over-blog.com
  • Chris King
    December 1, 2014 at 5:49 am
    There would probably lose some codec to play and read your MOV files in Adobe Premiere CC on your new computer. You can try to download and install a proper one. If you don’t want to spend time and effort to understand these complicated codecs and download them for video editing in Adobe PP, just change your MOV files to another file type that Adobe Premiere CC can fully support. As far as I know MPEG2 is a good for editing.By the way when install the Premiere CC on your computer, ever tried to restart it?
