Activity Forums Adobe Premiere Pro Premiere Pro CC stops loading file
  • Premiere Pro CC stops loading file
    Posted by Terry Jordan on January 17, 2014 at 10:13 pm
    I have edited a video in Premiere Pro CC. After I save and exit, my file can not be opened again. I get a window that says it is damaged. I un-install PP CC and then re-install PP CC and it opens. Then later the same “damaged” message shows up and I go through the same un-install and re-install. What is going on? My CS6 Premiere Pro never does this.
    Terry Jordan replied 12 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    January 18, 2014 at 2:20 am
    Hi Terry,
    Have you updated to the most recent version of Premiere Pro CC? Check out Help > Updates within the app.
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Terry Jordan
    January 18, 2014 at 1:56 pm
    Yes, I have the latest. In fact, I have to un-install and re-install the software from the Adobe Cloud to get Premiere Pro CC to work.
  • Kevin Monahan
    January 18, 2014 at 7:05 pm
    Sorry ’bout that Terry. You might try reposting your issue here: https://forums.adobe.com/community/download_install_setup?view=discussions
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • David Gaudio
    January 20, 2014 at 10:41 pm
    Hi Terry,
    I’ve had a similar problem. For the past half year, I’ve been editing promos for a series using CC. Whenever I exit the app, and restart it later, attempting to reopen a project, it will fail to open every time unless once I’m out of CC I do the following: trash my prefs using Digital Rebellion’s Preference Manager. This happens literally every time, so I always have Preference Manager open. It’s a free download:
    https://www.digitalrebellion.com/prefman/download.html
    I’ve found CC to be great, although it’s still very crashy. I think it may be due to the fact that the shows that I’m editing promos for are from .mxf files. For some reason, PP CC doesn’t like them (or at least certain versions of them), and the most recent 7.2 update was a disaster for me as a result (I had to roll back to 7.1). I hope Adobe is working on fix for the red flashes I was getting with 7.2 (7.2.0 or 7.2.1 for that matter).
    Anyway, try trashing your prefs with Preference Manager every time you try to open that problem project file. Only takes a couple of seconds, and it’s really saved my life with my own project!
    Good luck,
    David
  • Terry Jordan
    January 21, 2014 at 3:18 pm
    David,
    Does Preference Manager work with a PC?
    Seems the only one they offer is MAC.
    I have Windows 8.
    Terry Jordan
  • David Gaudio
    January 21, 2014 at 4:48 pm
    Hi Terry,
    Rats. Looks like Pref Manager is indeed Mac only. I wonder if there’s a comparable app out there for Windows…anyone?
  • Terry Jordan
    January 21, 2014 at 10:34 pm
    David,
    Is there a way to discard preferences within Premiere Pro?
    Terry
