Activity Forums Adobe Premiere Pro Premiere Pro CC Photo Slideshow
  • Premiere Pro CC Photo Slideshow
    Posted by Russell Tarbox on July 8, 2015 at 8:11 pm
    Hi all.
    Hope someone can help.
    I have raw photos from a DSLR. I will convert them to JPEGS.
    I plan to make a video file and play it on a widescreen HD tv.
    I need to know what sequence settings I should select before creation.
    I also need to know what output settings I need to select when the project is complete.
    Some information online mentions h.264.
    I am a bit confused and want to do it right.
    Thanks.
    Russell Tarbox replied 11 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Alex Udell
    July 8, 2015 at 8:50 pm
    Hi…
    how sophisticated do you want to get with this?
    there are a ton of templates available from sources like
    Pond5.com
    for slide shows that work great in After Effects.
    Might be worth a look.
    I’d also consider batch processing the images to a more video friendly resolution as raws from DSLR can be many more pixels (Width x Height) than HD video.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Russell Tarbox
    July 8, 2015 at 9:11 pm
    I will be processing the raw files and saving them as jpegs.
    I just want to use premiere for a simple slideshow with fades and titles.
    I don’t want to get too fancy at this moment.
    I want to get to grips with premiere first.
    Just need general help with sequence settings, and output settings to a UK HD widescreen TV.
    Thanks for your help.
  • Russell Tarbox
    July 10, 2015 at 3:37 pm
    Any help with the preset issue would be really helpful as this is the only hurdle for me.
    I know how to edit, add effects, etc
    It’s just what preset to use to output a photo slideshow and video project.
    Also what sequence settings to use for a photo slideshow and video project.
    I have looked online and most information is about posting to youtube, but i want to output to a file that will be put onto a hard drive, which is attached to a large widescreen HD TV.
    Thanks in advance.
  • Alex Udell
    July 13, 2015 at 1:18 pm
    Hi Russel…
    I’m not as familiar with European Standards…..So that’s why I had not chimed in….
    But essentially you want to choose an HDTV sequence.
    I’d guess a 1080 preset running at an appropriate frame rate.
    the fact that it’s a slide show really makes no difference. in this way of working you will still be creating a video file at the end of the day.
    Alex Udell
  • Russell Tarbox
    July 13, 2015 at 1:23 pm
    I will give that a go.
    Can I please ask another question?
    What output settings should i use? I have seen online that most people suggest using h.264.
    Is that ok to use?
    There are so many types, im not sure what is the best.
    Thanks again.
  • Alex Udell
    July 13, 2015 at 2:52 pm
    Hi Russell
    H264 is generally what we use for our deliverables.
    small footprint, good quality, generally compatible.
    I guess it would be helpful to know what the playback device would accept and work from there.
    Alex Udell
  • Russell Tarbox
    July 13, 2015 at 2:55 pm
    I guess the tv’s play most types, although 1 tv doesn’t like mkv so id like to stay away from that, just in case.
    H264 sounds like a good choice.
    I will try out your suggestions.
    Thanks for your assistance..
    Was very helpful.
