Activity Forums Adobe Premiere Pro Premiere Pro CC missing / dropping frames (See VIDEO) – bad rendering?
  • Premiere Pro CC missing / dropping frames (See VIDEO) – bad rendering?
    Posted by Jim Elliott on November 11, 2013 at 3:13 pm
    Hi, see here (1 min video) – https://www.youtube.com/watch?v=-fxWZbR8aN8
    Basically premiere pro CS6 AND CC keep missing frames on playback when dropped into timeline and colour graded etc compared to original, resulting in not-as-smooth playback. This happens at several points in the video that i have noticed and possibly a few more I havent!
    The only ‘solution’ i have come across so far is to mark in/out points in the sequence, ‘delete render files in to out’, and then render again. This worked for a couple of cases but not others, but not another 🙁
    It shouldnt happen at all – how many have i missed!?
    I should mention Im using a macbook pro retina, using mavericks
    Casey Culver replied 12 years, 9 months ago 4 Members · 4 Replies
  • Tim Kolb
    November 11, 2013 at 4:05 pm
    My first question would be whether this happens prior to changing over to Mavericks?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Casey Culver
    November 11, 2013 at 4:55 pm
    Do your clip settings match your sequence settings? Like for example you started your project with a 23.976 fps clip from one camera and you’ve dropped in a 29.97 fps clip from another?
    Also, you mentioned in your original description that it happens after color grading – if you export/render the same clip before grading, do the frames still disappear?
  • Soumendra Jena
    November 12, 2013 at 2:34 am
    Same is happening with me too.
    After I placed my color grading adjustment layers, the video is not smooth on preview.
    What could it be ?
  • Casey Culver
    November 12, 2013 at 3:13 pm
    Is it smooth when you export it? If it’s not smooth when you’re playing back, that could be simple cause you’re system is having trouble playing back all the unrendered effects – which is no biggie as far as delivering a good product is concerned. However, if it’s exporting with frames missing like originally pointed out, that’s no bueno.
