Activity › Forums › Adobe Premiere Pro › Premiere Pro CC Lumetri: only a few color effects seem to be working…
Peter Garaway replied 13 years ago 5 Members · 25 Replies
Rex Polanis
July 26, 2013 at 4:16 amagain, none of that works. It would be nice if Adobe would address this issue. Anyone with a AMD card using PPro GPU accelration and Lumetri looks is having this problem and I haven’t found a solution yet.
One man with courage makes a majority.
Canon 7D
Adobe CC Master Suite
Digital Juice
Video Copilot -
Peter Garaway
July 26, 2013 at 4:41 amHi Rex,
Can you tell us about your system? GPU, third party software, ect… Also which effects are causing you problems?
Peter Garaway
Adobe
Premiere Pro -
Rex Polanis
July 26, 2013 at 4:52 amWindows 7 64
AMD 8150 @ 4.6ghz
16 mbs DDR3 RAM
AMD FirePro v7900
ADOBE CC (Ae, Pr, Ai, Ps, Lr, Br, and Me)
Sony Vegas Pro 12
Cakewalk Sonar 7
BBE Sonic Sweet
Digital Jucie Juicer 3
Video CoPilot Element 3D v1.6.1
Red Giant Trapcode Suite v12.1It might help if you could tell me what to look for. I remember years ago on a different system I had line6 software and an Xbox controller software not getting along and causing problems.
Canon 7D
Digital Juice
Video Copilot -
Peter Garaway
July 26, 2013 at 6:37 pmHey Rex,
I don’t have the 7900 but I tested on the FirePro w8000 and w7000. I didn’t experience any issues. I was testing on the beta driver 12.104.2. You can find that on AMDs website.
Other useful information would be:
– Does this only happen when OpenCL is enable? How about in Software mode?
– Does it occur with all Lumetri effects or only specific ones? If specific, which?
– Only there any actions/steps that seem to cause the image to become corrupted?
Other things you may want to try:
– Uninstalling AMD catalyst and drivers and reinstall
– Uninstall your third party software one by one to see if any of them are the culprits (i know not fun and annoying). I’d start with Red Giant.
Sorry I couldn’t provide a easy fix. Please let me know about the first set og questions and I’ll investigate further.
Best,
Peter Garaway
Adobe
Premiere Pro -
Rex Polanis
July 30, 2013 at 3:20 pmTo answer your questions:
1. It only occurs when Open CL is enabled. But if I switch to software mode my previews lag and my render times are increased ten fold.
2. It occurs with all Lumetri effects
3. This seems to be a problem no matter what steps I take.
4. Uninstalled and reinstalled drivers ect, nothing changes
5. No third party software interference.One man with courage makes a majority.
Canon 7D
Digital Juice
Video Copilot -
Rex Polanis
July 31, 2013 at 2:33 amTo answer your questions:
1. It only occurs when Open CL is enabled. But if I switch to software mode my previews lag and my render times are increased ten fold. This is not a viable solution to a feature that should work when Open CL is enabled.
5. No third party software interference.I updated my driver to 12.104.2 had now instead of just crazy frames PPro CC crashes after previewing clips with lumetri looks applied.
Canon 7D
Digital Juice
Video Copilot -
Peter Garaway
July 31, 2013 at 3:08 amWell a crash actually might be more helpful here. Can you please send me a crash log and provide the steps that lead up to the crash.
If your not sure how to find a crash log here’s a link that shows steps.
https://forums.adobe.com/thread/900619
Thanks and very sorry for your troubles. Haven’t yet been able to repro your problems.
Peter Garaway
Adobe
Premiere Pro -
Rex Polanis
July 31, 2013 at 1:43 pmTo reproduce the problem, this is exactly what I do:
I use clips from two cameras (same brand and settings from two of the same DSLRs) I synchronize my clips and I add an adjustment layer with Lumetri looks applied above my clips. I only turn on the lumetri track to review after I have edited the clips because while reviewing my edited clips and after a few moments (30-60 secs), the preview screen will go all kinds of crazy colors or drop out completely.Also, if I export the clip, the export will have all kinds of crazy colored frames a few minutes into my project. The only work around is to go software based but like I said, it increases my export time ten fold if not more and slows done my work flow.
Canon 7D
Digital Juice
Video Copilot -
Rex Polanis
July 31, 2013 at 3:34 pmTo reproduce the problem, this is exactly what I do:
I use clips from two cameras (same brand and settings from two of the same DSLRs) I synchronize my clips and I add an adjustment layer with Lumetri looks applied above my clips. I only turn on the lumetri track to review after I have edited the clips because while reviewing my edited clips and after a few moments (30-60 secs), the preview screen will go all kinds of crazy colors or drop out completely.Also, if I export the clip to h.264 or mpeg2 the export will have all kinds of crazy colored frames a few minutes into my footage.
I have the System Info file. Where do send it?
Canon 7D
Digital Juice
Video Copilot -
Peter Garaway
July 31, 2013 at 6:14 pmCan you upload it to Dropbox or yousendit or one of those types?
Peter Garaway
Adobe
Premiere Pro
