Activity Forums Adobe Premiere Pro Premiere Pro CC – LOSING MARKERS via Media Browser.
  • Premiere Pro CC – LOSING MARKERS via Media Browser.
    Posted by Daniel Clark on March 25, 2014 at 6:42 pm
    Two editors are working on Premiere CC projects. Cloned drives. Virtually the same machines.
    We have logged ALL the footage with markers on one machine, and when opened a duplicated project file on the second machine, SOME, not all of the clips LOSE their markers.
    No real pattern we can see. At first, it was all of one folder, but it seems as if it’s a few select clips as well throughout other clips.
    WEIRDER STILL:
    I used Media Browser to grab the clip from the other editor’s project file. And when it comes in offline, it has ALL the markers. But when I replace or link the footage, THEY DISAPPEAR!
    This is upsetting and I need help ASAP! The other editor is crying FCP7. Would like to avoid that!
    Thanks.
    Matt Cowan replied 11 years, 6 months ago 4 Members · 3 Replies
  • Tim Kolb
    March 25, 2014 at 7:44 pm
    Are these clips all the same format?
    Is the metadata traveling with the media?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Claudina Bravo
    January 24, 2015 at 2:08 pm
    This happened to me as well.. What I did?.. copied SAME exact file to the location where the cloned project on HIS/HER drive is. IT NEEDS TO BE PHYSICALLY THE SAME EXACT FILE, for what you need to replace on his/her drive the file with the one you use while adding markers on YOUR drive.. Once replaced, open the copy of the “markers” project from his drive with the markers and they’ll translate.
    Not practical, I know.. and still an issue on CC 2014..
  • Matt Cowan
    March 5, 2015 at 6:11 pm
    I see that this is an older thread but I had the same issue and solved it with the same method above. By default Premiere stores markers with the media. Still the case but now that behavior can be disabled and markers will get stored with the project instead.
    Go to Preferences -> Media, and uncheck “write clip markers to XMP”
    This will take effect for future markers but unfortunately it’s not retroactive to existing markers so you have to copy the media over for those.
