Activity › Forums › Creative Community Conversations › Premiere Pro CC impressions
  • Chris Harlan
    August 29, 2013 at 11:15 pm
    [Andy Field] “What am i doing wrong?”
    I believe I can tell you exactly, because it is the same thing the flummoxed me at first. Make sure the track your are pasting to is selected, and then regular paste will suddenly be available in the menu.
  • Oliver Peters
    August 30, 2013 at 12:20 am
    For some recent reviews of mine – Premiere Pro CC and Media Composer 7:
    https://www.creativeplanetnetwork.com/2-pop/news/inside-creative-cloud-postproduction-adobes-new-premiere-pro-cc/63676
    https://www.creativeplanetnetwork.com/2-pop/news/avid-evolves-its-nonlinear-editor-media-composer-7-adds-frameflex-background-services/63677
    FWIW – these are not intended to represent “better than” or “worse than” in comparison to FCP X or anything else. Just the current state of things and how they apply for those who like or are interested in these applications.
    I like them both, but personally I’m still on FCP X for everything I’m currently doing.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Matt Galuszewski
    August 30, 2013 at 12:24 am
    It works on a Mac here.
    I select the transition and press COMMAND C to copy
    I then position the CTI over the cut and target the tracks I want to apply the transition to.
    I then press COMMAND V to paste
  • Cameron Clendaniel
    August 30, 2013 at 3:25 pm
    I have some small (but annoying) gripes (ie. fades to black when using GPU hardware acceleration are not smooth), but on the whole it’s a great NLE. Fast, flexible, and stable on a MacPro 5,1. Love the UI. Monitoring using Kona LHi is smooth. I’ve been using the DNxHD 220x sequence preset for all edits. No transcoding of media. Render then export using sequence settings using preview render files to an MXF file and it FLIES. AME is also very fast compressing the MXF to MP4, etc.
    Cameron Clendaniel
    Film Editor, NYC
    718-254-8027
    cam@camclendaniel.com
    http://www.camclendaniel.com
  • Andy Field
    August 30, 2013 at 8:00 pm
    Outstanding tip – thanks!
    Andy Field
    FieldVision Productions
    N. Bethesda, Maryland 20852
  • Kevin Monahan
    August 31, 2013 at 1:38 am
    The cool thing is that in Premiere Pro, the effects retain the same stacking order that you saved them in. In FCP filter packs, the filters would reorganize according to alpha numeric order when you save them as Favorites. You would have to rename them alpha numerically to make them stay in the same order, if I recall correctly. As most of you know, when your effects/filters are out of order, you can get a wildly different effect.
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Iain Anderson
    December 4, 2013 at 1:07 pm
    GenArts already makes Sapphire for FCP X:
    https://www.genarts.com/software/sapphire-edge/final-cut
    Free trial if you want to give it a go?
  • Justin Ferar
    December 4, 2013 at 3:58 pm
    Hi Lain,
    You are referring to “Sapphire Edge” which is not even close to the full Sapphire suite. $400 vs $2400. It’s just a bunch of barely customizable quick pre-sets.
    I asked GenArts if they plan on supporting X with the full suite and they basically said no current plans.
  • Iain Anderson
    December 4, 2013 at 11:37 pm
    Ah, got it. I guess if you’re really happy with the plug-ins you’d want to keep using them, but from the outside, them seem expensive for what you get. Clearly I’m biased, as I create promo and tutorial videos for CoreMelt, but CoreMelt Complete looks like it overlaps quite a bit. If you really can’t find what you’re looking for, the ability to roll-your-own FCP X effects/transitions/titles in Motion is incredibly helpful.
Page 4 of 4
