Activity Forums Adobe Premiere Pro Premiere Pro CC Frame Smoothing
  • Premiere Pro CC Frame Smoothing
    Posted by Andrew Shelton on March 8, 2021 at 6:24 pm
    Hey guys. Sorry if this is a stupid question but it’s been a while since I’ve used Premiere. I have a clip that I am editing. It’s only one clip at 29.973fps and it will be exported at same frame rate. I noticed the clip (played normally before importing to PR) doesn’t have a smooth motion frame by frame so when you play it it seems to have a very slight stutter. What would be the best option to smooth motion? I know Premiere has Frame sampling/blending. Would exporting with this setting help smooth the frames out or does this only work when you have multiple clips at different frame rates? Any other options?
    Andrew Shelton replied 5 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
