Activity › Forums › Adobe Premiere Pro › Premiere Pro CC Export To Tape
Posted by Marcus Smith on May 6, 2013 at 9:52 pmHi Premiere Pro CC beta testers,
Does anyone know if the (supremely terrible) export to tape function in Premiere got the much needed overhaul in CC? Or does the cloud master my tapes now?
Cheers,
Marcus.
Jeff Pulera replied 13 years, 4 months ago 4 Members · 9 Replies -
Kevin Monahan
May 6, 2013 at 10:12 pm[Marcus Smith] “Does anyone know if the (supremely terrible) export to tape function in Premiere got the much needed overhaul in CC?”
I do. There is a new Export to Tape panel that is available with installed third party hardware.
Kevin Monahan
Social Support Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Kevin Monahan
May 6, 2013 at 10:41 pmI don’t have a third party card in my rig, so I wasn’t able to test it. From what I’ve heard, it’s pretty awesome, though.
Kevin Monahan
Social Support Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Alex Gerulaitis
May 6, 2013 at 10:44 pm[Kevin Monahan] “I do. There is a new Export to Tape panel that is available with installed third party hardware.”
No FireWire support then? (Have a client who can’t see to export to tape (to DSR-11 or similar decks) in CS6: no signal in video.
Alex Gerulaitis
Systems Engineer
DV411 – Los Angeles, CA -
Kevin Monahan
May 6, 2013 at 10:58 pmThere are two Edit to Tape panels now, the existing one for DV/HDV and a new one for SDI.
Kevin Monahan
Social Support Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Jeff Pulera
May 7, 2013 at 3:39 pmHi Alex,
The main difficulty in getting DV export to work with CS6 is that the Mercury GPU-acceleration must first be set to “Software only” for some reason.
Jeff Pulera
Safe Harbor Computers -
Alex Gerulaitis
May 7, 2013 at 8:17 pmAwesome, thanks Jeff. (Met a couple of your coworkers at NAB, cool dudes; missed you there.)
I think the client already tried that (setting GPU acceleration to software), but I’ll email him to make sure.
Thanks again.
Jeff Pulera
May 7, 2013 at 9:40 pmHi Alex,
Wish I could’ve been there, maybe next time.
There are actually several hoops to jump through to get DV output working, took me a while to succeed the one time I needed to do it with CS6. Also check under Edit > Prefs > Playback and set up the various checkboxes for the DV Output. Audio also needs to be enabled or you get a silent movie on tape. Don’t have access to the CS6 PC right now to look at the options or I could be more specific.
Jeff Pulera
