Activity › Forums › Adobe Premiere Pro › premiere pro cc clip markers visible in timeline
Posted by Christina Crawley on August 8, 2013 at 6:12 pmI saw some previous posts on this – any movement? Any way to see a clip marker while in the timeline?
Martin Nelson replied 11 years, 3 months ago 9 Members · 11 Replies -
Ann Bens
August 8, 2013 at 8:11 pmGo to the Timeline Display Settings (wrench) and check Show Clip Markers.
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional -
Miles Dahl
October 23, 2013 at 4:30 pmTo add to this, it seems that in Premiere CC you need to expand your track vertically a bit to make the Clip Keyframes visible.
Tomek Dyszkiewicz
March 4, 2014 at 8:37 amIs there a way to make them visible even though clip “vertical size” is minimum?
Robert Lewis
April 3, 2015 at 4:47 amYes, this is a huge help when cutting… not sure why this feature isn’t a given.
Christina Crawley
April 3, 2015 at 1:43 pmYeah I’ve just adapted to expanding my track vertically so it is a little thicker, seeing them instantly while being at the minimum track height would be great!
Ht Davis
April 6, 2015 at 4:07 amRemember this:
The types of keys, and gradual variation between them can span a large vertical, as well as horizontal area. As such, there is a minimum display size set to prevent inaccuracy. IF your screen isn’t big enough for this, try attaching a second screen and moving some of your panels over to it. Keep your sequence panel on it’s own and expand as much as needed to see them. The second screen wouldn’t need to be very big, and it could have a low resolution, so it wouldn’t tax your GFX processing. I use a 50 inch TV, and put my sequence on that… It’s great for syncronizing audio…
Marc Serhan
May 26, 2015 at 6:33 pmOMG, thank you. This was driving nuts. Still can’t figure out how to add a marker to a clip in the Timeline.
Thank you.
Robert D’alexis
May 26, 2015 at 7:53 pm@ Christina & Robert
This feature is implemented in the next version of PPro coming soon.
Marc Serhan
May 27, 2015 at 3:02 pmYes, I got it, but ONLY after I saw your initial tip about track height. I wasn’t seeing them before.
Thanks again.
