Activity Forums Adobe Premiere Pro Premiere Pro CC – Audio Track Fade Resetting on Restart
  • Premiere Pro CC – Audio Track Fade Resetting on Restart
    Posted by Matt Nevs on December 8, 2016 at 2:57 pm
    I’m having a strange issue with Premiere Pro CC that I cannot seem to resolve:
    In the Audio Mixer panel, I have a track that keeps resetting the volume fade to 0 on playback. I have this fade set to -10 and want the entire sequence to stay at this level for that entire track. As far as i’m aware, I’ve not placed any automation on this audio track or the chain of audio plugins I have on the track. There are two audio tracks on this sequence and the other remains static at the volume I’ve set on the fade, which is what I want. Here is what I’ve tried:
    1.) Selecting all audio on this track and selecting “remove effects” (in case I accidentally placed some automation), then setting volume fade to -10 with automation mode set to “Off”. Upon reboot of the software, volume will be set to -10 then jump back to 0 when I press play.
    2.) Setting automation mode to “Off”, and setting volume fade at -10. Upon reboot of the software, volume will be set to -10 then jump back to 0 when I press play.
    What causes this behavior and how do I ensure that my effects and volume will remain static throughout the sequence?
    Jon Doughtie replied 9 years, 6 months ago 2 Members · 1 Reply
  • Jon Doughtie
    December 12, 2016 at 4:41 pm
    Matt, let us know more information about your system and the exact version of Premiere Pro you are using.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
