Activity Forums Adobe Premiere Pro Premiere Pro CC Audio playback unacceptable
  • Premiere Pro CC Audio playback unacceptable
    Posted by Pete Pedulla on January 29, 2014 at 3:09 am
    Like many, I switched to Premiere from FCP a while ago. I’ve been struggling retraining my brain, and spent last summer working on a fairly intensive project. Towards the end of that project, the audio starting playing back badly. Either with pops and static in the background. Or stuttering and stopping and dropping out altogether.
    I got through that and thought maybe the project was corrupt or something.
    I started a new project and I’m having the same issue. I see from the Adobe support forum, others do, too. But, there I couldn’t find a solution.
    Anyone have any clues? It’s so bad, I can’t really do my project, and I’ve had at least one embarrassing client meeting where I tried to play a cut back for them after making a few changes, and it just wouldn’t play. I had to ask them to wait until I put the file out as ProRes and then played that back via QT player.
    At this point Premiere Pro CC is just not workable for me.
    BTW I’m using an iMac, OSX 10.9.1, 32GB ram, no CUDA processing.
    Pete
    Pete Pedulla
    Creative Director
    2PM Productions, LLC
    Greg Flick replied 12 years, 2 months ago 6 Members · 13 Replies
  • 13 Replies
  • Tero Ahlfors
    January 29, 2014 at 4:49 am
    What I/O do you have? Are you running other programs? What are the formats for the problematic audio files?
  • Pete Pedulla
    January 29, 2014 at 1:01 pm
    No I/O, just working off the computer.
    This project was shot on a Sony F5. Audio is embedded on the .mxf video files. Music from an .aiff file.
    Previous project shot on a Nikon DSLR. Also had problems, though this time it’s worse.
    In both cases, the problem only appears towards the end of editing. So, in this case, I got through 5 days of editing with no issues, and only in the final stages, did the playback begin to fail.
    Pete Pedulla
    Creative Director
  • Vince Becquiot
    January 29, 2014 at 4:42 pm
    I have a feeling this may have to do with the Mavericks update.
    Vince Becquiot
    Indigo Live
    Kaptis Media
  • Peter Garaway
    January 29, 2014 at 6:12 pm
    Hi Pete,
    Sorry to hear your having troubles.
    Have you tried clearing your prefs? You trash all folders found here:
    /Users/[username]/Library/Application Support/Adobe/Common
    Also, can you give more details on your system specs? Why no GPU?
    Peter Garaway
    Adobe
    Premiere Pro
  • Ericbowen
    January 29, 2014 at 6:53 pm
    It would not be unheard of for the audio conform files to corrupt. Delete all of the files in the media cache folder while Premiere is closed. Then launch Premiere and let it re-conform. See how the audio is then. If that doesn’t work go under preferences and audio device. Check mark the box for 32bit playback I believe it’s called. See if that changes the output.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Pete Pedulla
    January 29, 2014 at 9:22 pm
    Thanks for taking the time to reply to my rant. (I was frustrated last night.)
    The file path you list isn’t exactly the same on my iMac. I find this path:
    MacHD/Library/Application Support/Adobe/Common
    Then, in the “Common” folder I have 3 folders:
    dynamiclink
    dynamiclinkmediaserver
    Plug-ins
    Are these to be trashed?
    Also, about my system:
    iMac OSX 10.9.1 “Mavericks”
    2.93 Intel Core i7
    ATI Radeon HD 5750 1024MB
    Thanks, again for all your help. Please advise if I should trash the above three folders
    -Pete
    Pete Pedulla
    Creative Director
  • Pete Pedulla
    January 29, 2014 at 9:25 pm
    Thanks so much.
    Is the media cache folder the one called “Adobe Premiere Pro Preview Files,” with a subfolder comprised of the project name and extension .PRV?
    Pete
    Pete Pedulla
    Creative Director
  • Peter Garaway
    January 29, 2014 at 9:59 pm
    There are 2 different Common folders. The path I gave is to the User library, that’s where you’ll find the cache files.
    Apple has hidden the User library I beliebe since 10.7. Here’s to ways to get there:
    Method 1
    In the Finder, choose Go > Go To Folder.
    In the Go To Folder dialog, type ~/Library
    Click Go.
    Method 2
    Hold down the Alt (Option) key when using the Go menu. The user library folder is listed below the current user’s home directory.
    Once there follow this path:
    Peter Garaway
    Adobe
    Premiere Pro
  • Ericbowen
    January 29, 2014 at 11:19 pm
    https://provideocoalition.com/ssimmons/story/Clean_those_adobe_media_cache_files
    Go to the folder location and delete the files. The Clean option in the applications only deletes the references and not the media cache files.
    Eric-ADK
    Tech Manager
  • Pete Pedulla
    January 30, 2014 at 2:43 am
    Eric,
    Thanks. That was really helpful. Clearing the cache this way helped but did not solve my problem. In other words, my audio still has subtle, static “pops” intermittently under.
    However, unlike before, at least it seems to play without stopping and cutting out entirely.
    This will help so I can finish the project, but I will need to find a long term solution.
    ~Pete
    Pete Pedulla
    Creative Director
