Activity › Forums › Adobe Premiere Pro › Premiere Pro CC and Canon MXF problems
Michael Williams
May 29, 2014 at 2:44 amI’m curious about a possible workaround. I’ve never used Prelude before, but if I was able to ingest the spanned clips into Prelude with the correct timecode, how would I move those new versions of the clips from Prelude to Premiere?
thanks again,
Mike
Kevin Francis
May 29, 2014 at 7:50 amHave you tried a new CC project and importing the files into it instead of the CS6 upgraded project? Also, we find it works best to transcode to ProRes if you’re doing a major edit- a little more hassle on the front end (not much!) but way easier during and after the edit.
Paul Neumann
May 29, 2014 at 2:44 pmMark and ingest your clips in Prelude, highlight, right click, send to PPRo.
If you have a project open they will land in the Project bin. If you don’t it will create a project to the clips specs and put them there.
Michael Williams
May 29, 2014 at 3:22 pmI think this is my way forward. I just brought all of the spanned clips into prelude and it seems that they have the correct timecode. So now I should be able to replace those sections in my original project and move forward from there.
Still not sure what happened, but at least I can move on with the project from here.
thanks for all your help.
mike
Michael V. Williams
producer/editor
http://www.vernonvision.com -
Michael Williams
May 29, 2014 at 3:23 pmyes, I tried that and it didn’t help. perhaps I will go back to my old process of transcoding pre-edit in the future.
thanks,
mike
Tim Kolb
May 29, 2014 at 4:47 pm[Michael Williams] “perhaps I will go back to my old process of transcoding pre-edit in the future.”
I can certainly understand that sentiment, though something is definitely wonky in this scenario (not implying it’s your fault, just that this isn’t really a common issue)…
If you start a new CC project and use the Media Browser to import a file you know is one of the oddly behaving spanned clips, what happens then?
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Frank Tourv
June 1, 2014 at 9:01 pmI have resolved the c300 problem(and i had plenty of stuff shot with it), by deleting the .xml,.cif,.sif and occasional .cpf of every folder. I use the finder and delete them in bunch(and dont forget to empty trash),only leaving the .mxf. Note that once you have done that, you need to create a new project, clean the media cache and then re-import every c300 files. So far that handled it completely.
Michael Williams
June 2, 2014 at 3:18 pmInteresting, Frank.
pardon my ignorance of the format, but if we delete all of those files (which I always assumed were for metadata) to make it work correctly, then why are they created in the first place?
thanks for the info.
Mike
Frank Tourv
June 3, 2014 at 9:03 pmthe metadata is there for the Canon XF utility app and the c300 itself which is somewhat useful for viewing clips and transferring, but i find it more useful to do an all adobe workflow using Prelude to get data off the cf card to two separate harddrives simultaniously and previewing my footage. After that, i send my stuff to premiere(you can also skip the prelude part and just drag and drop your stuff through finder also).
Note that deleting these will unable final cut X from importing these MXFs using the canon XF plugin for fcpX. In a weird way, fcpX needs the metadata, while premiere doesnt want it. This is a flaw from adobe only related to the canon c100/300/500 – dslrs dont cause this problems, so does XMLs from Sony cameras.
Michael Williams
June 3, 2014 at 9:17 pmInteresting. I think I will try your approach with prelude on my next project with the Canon xf files.
Thanks, Frank.
mike
