Activity › Forums › Adobe Premiere Pro › Premiere Pro CC (7.2) and Premiere Pro CC 2014 on same machine?
  • Premiere Pro CC (7.2) and Premiere Pro CC 2014 on same machine?
    Posted by Jamie Pickell on August 24, 2014 at 1:24 pm
    I’m in the process of setting up a new system drive for my MacBook Pro running OS 10.9.4 Mavericks. I downloaded the Creative Cloud install app and loaded the 2014 versions of the various programs. I would like to install the older version of Creative Cloud (Premiere CC 7.2) on the same machine. However, when I go to run an earlier version of the Creative Cloud install app it asks me if I want to revert to the earlier CC software and thus blow away the 2014 apps. Can you have both Premiere Pro CC (7.2) and Premiere Pro CC 2014 installed on the same machine? If so, how do you do it?
    Thanks in advance,
    Jamie
    MBP 10.9.4
    2.4 i7
    16GB RAM
    Adobe CC
    FCS 3
    Avid MC 5.5
    Jamie Pickell replied 12 years ago 5 Members · 5 Replies
  • Ann Bens
    August 24, 2014 at 5:45 pm
    CC7 and CC14 can live happily together on one machine.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Gary Milligan
    August 24, 2014 at 6:10 pm
    [Jamie Pickell] “However, when I go to run an earlier version of the Creative Cloud install app it asks me if I want to revert to the earlier CC software and thus blow away the 2014 apps.”
    Is there an option to say “no”? You may have to install the old version first and then re-install CC2014.
    HTH
    Gary
  • Mark Landman
    August 24, 2014 at 7:41 pm
    I suppose you could uninstall the 2014 apps, install the CC apps and then reinstall the 2014 apps. Both versions can coexist on the same machine with no problems.
    Mark Landman
    PM Productions
    Champaign, IL
  • Jp Pelc
    August 27, 2014 at 2:25 pm
    No no no. You can have both running on the same machine and it is easy. Just keep the newest version of the CC desktop app installed. Click the app from the menu bar and on the Apps tab, scroll down till you see “All Apps”. Click it and you should see a dropdown where you can select “previous versions”. From there you can install CC or even CS6
  • Jamie Pickell
    August 27, 2014 at 2:52 pm
    Thank you everyone. I found the following on Adobe’s site written by Kevin:
    https://blogs.adobe.com/kevinmonahan/2014/01/29/revert-to-a-previous-version-of-premiere-pro-cc-or-any-creative-cloud-application/
    I was able to install the previous versions of CC alongside the 2014 versions.
    Cheers,
    Jamie
