Activity Forums Adobe Premiere Pro Premiere Pro CC 2018 – problems importing 1080HD AVI files
  • Premiere Pro CC 2018 – problems importing 1080HD AVI files
    Posted by Bruce Rutland on February 21, 2018 at 10:45 am
    I’m trying to import 1080HD AVI files into Premiere Pro CC 2018 (PC Windows) and I keep getting a “File Import Failure” message “Unsupported format or damaged file” and can’t continue. I’ve been using PP CS5 up to now and just switched to the new version yesterday. I’ve never had a problem before. I know it’s not a corrupt file as have tried dozens of files and they were all fine in the previous version.
    Any ideas? Thanks in advance. Bruce
    Bruce Rutland replied 8 years, 6 months ago 3 Members · 5 Replies
  • Tero Ahlfors
    February 21, 2018 at 11:00 am
    Where did this file come from and what codec is in it?
  • Bruce Rutland
    February 21, 2018 at 11:39 am
    Thanks for the reply.
    This is all the information I could find on the file formats…
    Video
    Frame width 1920
    Frame height 1080
    Data rate 63139kbps
    Total bitrate 64675kbps
    Frame rate 25 frames/second
    Audio
    Bit rate 1536bps
    Channels 2 (stereo)
    Audio sample rate 48 kHz
  • Bruce Rutland
    February 21, 2018 at 11:43 am
    It was originally captured in Premiere Pro CS5 from a Blackmagic Teranex 2D using a Decklink SDI 4K (Blackmagic) card.
  • Jeff Pulera
    February 21, 2018 at 8:24 pm
    You need the Black Magic M-JPEG .avi codec to play those files, available by installing Black Magic capture card drivers.
    Go to this page: https://www.blackmagicdesign.com/support/family/capture-and-playback
    Look under Latest Downloads – Desktop Video 10.9.11 for Windows
    Click WINDOWS then skip entering any info and select DOWNLOAD ONLY at lower left. Download and install driver, then you should be able to play/edit those files. CLOSE Premiere when installing.
    Jeff
    Jeff Pulera
    Safe Harbor Computers
  • Bruce Rutland
    February 27, 2018 at 8:25 pm
    Thanks Jeff – I followed your instructions and all working now!
    You’re a star… All the best, Bruce
