Activity › Forums › Adobe Premiere Pro › Premiere Pro CC 2015.3 Transition Glitches (Green)
  • Premiere Pro CC 2015.3 Transition Glitches (Green)
    Posted by Blaize Warden on September 6, 2016 at 3:59 am
    I’ve been attempting to add transitions to several clips in my Premiere Pro sequence but I’ve run into problems with 4 random clips.
    Most transitions have worked, but I am having problems at 4 specific points.
    As you can see in the video I’ve attached, I am getting a weird green glitch error.
    Some of the clips are after effects sequences, others are standard footage.
    I’ve tried replacing the footage, nothing works.
    Note: I have an adjustment layer with Trapcode Looks.
    Check item description for timecode: https://www.youtube.com/watch?v=RaHOb40RKQU
    Blaize Warden replied 10 years ago 2 Members · 2 Replies
