Activity Forums Adobe Premiere Pro Premiere Pro CC 2015 crash on export
  • Premiere Pro CC 2015 crash on export
    Posted by Joseph Hall-patton on August 11, 2015 at 11:17 am
    I have been trying variations of fixing this error, but to no avail. I just recently switched to CC 2015 (from CS6), along with Windows 10 (from Win7). When I went to export a new project, the PC freezes, with no BSOD or anything. I changed graphics cards, and that seemed to make it only freeze the program, rather than the entire PC. But on the third try, the different card froze the system as well. I was able to take the files over to my laptop, which completed the export with ease, so I am very confused now. Here are my system specs:
    Desktop:
    Windows 10 Pro
    CPU: AMD FX-8350
    GPU: AMD R9 270x (or) nvidia GTX 670
    RAM: 16gb 1866
    Motherboard: Asus m5a97 r2.0
    HDD: 2tb main + 4tb data (both 7200rpm)
    Laptop:
    Windows 10 Pro
    CPU: Intel i5-430m
    GPU: ati 5750m
    RAM: 4gb 1333
    Motherboard: MSI gx640
    HDD: 500gb 5400rpm
    I’ve tried wiping caches, reinstalling Premiere Pro, resetting defaults, updating drivers, playing with the encoding settings, using separate drives, and checking for Windows corruption. Despite all of that, it still freezes, and without a BSOD, I can’t even see the error in the system log. I’m able to render on my 2009 laptop, but that decrepit thing is too troublesome. Please help.
    Joseph Hall-patton replied 10 years, 10 months ago 4 Members · 5 Replies
  • Rob Baker
    August 20, 2015 at 7:30 pm
    Same here. As soon as I click “Export” I get the error message. I’ve updated my Nvidia drivers and uninstalled all of Creative Cloud.
  • Gareth Croft
    November 21, 2015 at 12:30 am
    Hi, did you manage to fix this issue? I’m getting the same with an identical spec PC 🙁
  • Joseph Hall-patton
    November 21, 2015 at 11:17 pm
    So far as I can tell, it is a problem with the motherboard drivers. The m5a97-r2 has not had a chipset update since window 8 (not 8.1). I contacted the support team about when the drivers would be updated, and they said it would be “soon,” of course that was back in late-August. There must be some sort of PCI bridge error between the GPU and CPU. That’s the only way I can explain it. I just loaded a secondary hard drive with Windows 7 and switch to that OS for all of my video editing.
  • Matt Anderson
    November 23, 2015 at 3:54 pm
    It seems silly but have you tried making the destination a local drive and then used Que to Media Encoder?
    November 23, 2015 at 6:28 pm
    Certainly. I’ve got 3 different drives, and I’ve tried exporting to all of them in several different ways. All fail in the same way.
