Activity Forums Adobe Premiere Pro Premiere Pro cannot open any project
  • Premiere Pro cannot open any project
    Posted by Bodybuildingbs on July 17, 2005 at 9:04 pm
    Premiere pro all of a sudden decides it cannot open any project..it starts and the little progress bar gets alllllllllmost to the end and it just freezes. I tried to even open simple projects with only 2-3 clips and maybe less than a minute in length and the same thing.
    Went in and deleted the prefs file but no go.
    Please advise and thank you.
    Aanarav Sareen replied 21 years, 2 months ago 3 Members · 3 Replies
  • Craig Howard
    July 17, 2005 at 10:08 pm
    Can it start (open) a new project ?
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Bodybuildingbs
    July 18, 2005 at 1:33 am
    Yes it can but then I tried to import another project and it just stalled…it sits there while the memory just keeps dropping (I use pc booster and can visually see it…) and then I have to go into task manager and manually stop premiere pro…this does NOT happen with premiere 6.5 any ideas
  • Aanarav Sareen
    July 18, 2005 at 2:50 am
    What other “booster” programs do you have? Seems like a software conflict. If this started happening recently, did you install and new software or hardware? If so, disable the hardware and use system restore to roll back the system to the last known good configuration.
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
