Activity › Forums › Adobe Premiere Pro › Premiere Pro Automatically crashes after it asks me to relocate media
Posted by Steven Sproul on July 14, 2013 at 5:55 pmEverytime I open up this premiere pro file, it asks me to relocate a certain file, and I find the file and I click ok and then the project opens up and then I get the beachball and then the premiere pro closes automatically
Larry Asbell replied 13 years, 2 months ago 3 Members · 8 Replies -
Angelo Lorenzo
July 14, 2013 at 6:49 pmWhat happens if:
1) You choose to offline the file?
2) You add the file to a brand new project. Does Premiere Read it? Close Premiere and reload the new project, same issue?
Where did your footage come from? What operating system and Premiere Pro version?
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Steven Sproul
July 14, 2013 at 7:28 pmI tried choosing offline and the project file still automatically closes out.
I opened up an auto-saved version of the project file and it opened up fine.
I also open a new project and placed in the GoPro footage and saved it and reopened the new project file and everything worked fine.
I am using Premiere Pro 5.04 with a Macbook Pro 10.8.04 version
I’m thinking that the original project file somehow became corrupt but I don’t know how
Angelo Lorenzo
July 14, 2013 at 7:30 pmCorruption of project files happens every so often. If the auto save works, then great! In the future, importing an old project into a new project solves a lot of similar issues as well.
Steven Sproul
July 14, 2013 at 8:01 pmWhat do you mean by importing an old project into a new project, I’ve never done this?
Angelo Lorenzo
July 14, 2013 at 8:07 pmStart a new project, go to Menu > File > Import and select your corrupted project file. It will import into your bin as files, folders, and sequences.
Steven Sproul
July 14, 2013 at 8:28 pmScratch that, I tried importing it into a new project and premiere still crashed
Larry Asbell
July 14, 2013 at 10:18 pmHow about ridding your project of the problem clip, i.e. remove all clips of it and remove it from all sequences. Then after checking that your project is stable, reimport the clip and add it back to the sequence. If that fails, convert the clip to another codec. Not that there is anything wrong with the codec but the conversion might remove a corruption.
