Activity Forums Adobe Premiere Pro Premiere Pro audio problems
  • Premiere Pro audio problems
    Posted by Ludwig Hanzl on April 12, 2005 at 6:26 pm
    My problem is the large time spend to make audio for my travel videos. There are procedures that are always the same. There is a original audio trace a music trace and a trace for comments with many clips (e.g. 100). Always when there is a comment clip the music trace and/or the original audio trace has to decrease (e.g. 30% sound intensity with ramps). It is a hard work to make it with the pencil tool (in P.6.5 there was a double keyframe in Pro I did not found). Are there possibilities to automate these procedures? To cut the music clip always at the beginning and end of the comment clips and work with a copy function is also much hand work because of the ramps. How would an expert solve this problem? Best thanks for each assistance. Ludwig.
    Steven L. gotz replied 21 years, 4 months ago 2 Members · 1 Reply
  • Steven L. gotz
    April 12, 2005 at 8:33 pm
    With practice you could do it with the audio mixer controls. Just write to the correct track and as you see the comments coming, you pull down the audio of the other tracks. You may have to use a submix to get two tracks to drop at the same time.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
