Activity Forums Adobe Premiere Pro Premiere Pro Audio Levels/Audio Loudness for Broadcast
  • Premiere Pro Audio Levels/Audio Loudness for Broadcast
    Posted by Jonnie Lewis on May 9, 2014 at 3:48 pm
    Hello,
    I’m delivering a file for broadcast and have been given a spec sheet that has some audio settings which need to be met. Could someone please give me guidance on how to handle these settings within Premiere Pro?
    Audio Levels:
    Audio reference lineup should be -18dBfs (0 dBu / UK ppm 4)
    Peak program level should not exceed -10dBfs (+8dBu / UK ppm 6)
    Speech should be between -18dBfs to 13 dBfs (UK ppm 3 to 5)
    Audio Loudness:
    Digital files should be supplied to comply with EBU-R128 / ITU-R BS1770 loudness specification.
    Audio loudness target should be set to -23LUFS.
    Any help much appreciated!
    Many thanks.
    Jonnie Lewis replied 12 years, 3 months ago 2 Members · 2 Replies
  • Chris Borjis
    May 10, 2014 at 12:07 am
    sounds like the “CALM ACT” levels.
    Premiere CC comes with a great metering plugin called “Loudness Radar”
    just add it to your audio track then play it.
    It should not go below -22
  • Jonnie Lewis
    May 22, 2014 at 12:45 pm
    Hi Chris,
    Thanks for this tip. Any other info regarding the other specs?
    Audio Levels:
    Many thanks again.
