Activity Forums Adobe Premiere Pro Premiere PRO audio export for DAW
  • Premiere PRO audio export for DAW
    Posted by Yerb Khan on January 7, 2015 at 8:03 am
    Hello,
    I need to export audio tracks to nuendo via OMF/AAF under following condidions:
    – full lenghth audio files
    – original audio file names
    – no edits
    – no fades
    – no effects
    – stereo (not separated mono files)
    Since the sequence which I need to export has already been edited, I need a solution to excport clean audio with parameters mentioned above. Is this even possible.
    Alex Udell replied 11 years, 8 months ago 2 Members · 1 Reply
  • Alex Udell
    January 7, 2015 at 1:56 pm
    OMF shouldn’t pass any FX as those filters are specific to PPro.
    PPro export includes option of copying the Complete audio
    no edits — you’ve done edits…but my understanding is that with complete audio copies, the OMF will include a complete audio file for every usage of a piece of media in the timeline (even if it’s the same source used ore than once)
    fades — you probably need to take your picture lock timeline and dupe it and prep it to get rid of any offline key level key framing you may have done…I don’t think fade transitions would translate anyway…
    but to be sure….before you invest a lot of time prepping….
    dupe your sequence and cut it down to a short but complex area….prep that…
    make an OMF and pass it…
    see what they get on the other side…
    work with the engineers and they’ll tell you what you need to adjust in your prep.
    may take a few times thru….but ought to be workable…
    all about developing the pipeline….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
