Activity Forums Adobe Premiere Pro Premiere Pro audio dub workflow
  • Premiere Pro audio dub workflow
    Posted by Andrew Johnstone on November 11, 2014 at 10:56 am
    I am trying to figure out how to output audio form Premier Pro for an audio dub. In FCP7 I was able to send an OMF file to the sound designer to do a bit of knob tiwddling on, but I confess I simpy do not know what the workflow for PP should be.
    I have a very simple 4/5 track audio edit to do on a documentary project, which I know I can actually do in PP itself, but I am not an audio genius (I never know which filter to use and how to use it) and I have not really figured out how to the the audio mixer in PP very well. In FCP the audio mixer does a live mix on each track, but in PP I think you need to select various options to create a live mix scenario and to me the process is just a little more clunky.
    “Why are you using PP then?” Well it has just been sort of thrust on me since FCP7 was pulled and I am just trying to use PP on all material that does not need to be cut on FCP7 (which I still use all the time BTW…).
    Thanks for any help.
    Andy Johnstone
    Wild Dog Limited
    film & multimedia production
    http://www.wilddogworld.com
    Andrew Johnstone replied 11 years, 9 months ago 2 Members · 2 Replies
  • Andy Edwards
    November 12, 2014 at 7:20 pm
    Premiere has OMF export if you are on CC2014.
    Other option, round trip your audio to Audition and export the stems to send to your sound designer. Just put in some tone on the front end to have a consistent marker you can re-sync up when you get tracks back.
    Andy Edwards
  • Andrew Johnstone
    November 17, 2014 at 4:03 pm
    Thanks Andy,
    Yes I found the OMF Export tool and that all worked pretty well.
    The main issue for me is knowing what knobs to press in Audition and which filters work best for what. It was just easier to give the work to our local audio studio to mix down for me!
    Andy
    Andy Johnstone
    Wild Dog Limited
