Activity › Forums › Adobe Premiere Pro › Premiere Pro and long form
  • Premiere Pro and long form
    Posted by Oliver Peters on January 16, 2013 at 5:53 pm
    I’m curious what the experiences have been with folks working on long-form jobs like documentaries and movies. More than 60 minutes in length and 20 hours of footage. What have the experiences been – good and bad? Any successful workflow tips or things that throw the project off the rails? I’m asking this same question of the FCP X folks, too, BTW. Thanks.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Oliver Peters replied 13 years, 8 months ago 3 Members · 3 Replies
  • Dennis Radeke
    January 17, 2013 at 11:13 am
    The biggest potential pitfall is users not installing enough RAM. With a 64-bit system, the answer to traditional long-form woes is to add more memory. We started to see this in CS4 which was ’64-bit addressable’ – 32bit app that could address more than 4GB of RAM with doc users.
  • Walter Biscardi
    January 17, 2013 at 8:08 pm
    Oliver so far so good here. We transitioned around May / June of 2012 and honestly we’ve yet to run into any sort of issue caused by project size / media amount.
    We’re still running on our 48TB SAN from Small Tree, up to 8 workstations connected at any given time, CS6 on all systems and nary a worry so far. We did the entire second season of This American Land for PBS on there with each episode running anywhere from 20 – 40 hours of raw material over 13 episodes. Editors pulling from each others shows as necessary. We have more documentary projects and reality / docu-series type of work lining up for 2013 and all of it will go into PPro.
    The big key…… let me say that again….. THE BIG KEY to making large projects work in PPro is media management. It’s completely different than what you’re used to in FCP 7. PPro makes you do a lot of media management yourself. On the front end, it’s a little bit of a pain when you get started into the application but the more you use it, the more we appreciate that at the end of a project, we simply need to move one folder over to Archive an entire project.
    I cannot recommend enough Richard, Robbie and Jeff’s book “An Editor’s Guide To Adobe Premiere Pro.” This should actually come standard with every copy of CS that’s sold to someone switching from another NLE. Get the media management chapter down and follow Richard’s plan.
    Also accept that you CAN work completely natively with everything during your rough cut phase. Do NOT spend wasteful time converting everything under the sun to a single format / frame rate until you have a locked cut. Once we accepted that workflow really does work, we have become much more efficient in our projects. I documented our current workflow here on the Cow recently.
    https://magazine.creativecow.net/article/workflow-update-imac-adobe-the-x-factor
    Any further questions about specific workflows, etc…. feel free to contact me directly.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    Foul Water Fiery Serpent, an original documentary featuring Sigourney Weaver. US & European distribution by American Public Television
    MTWD Entertainment – Developing original content for all media.
    “This American Land” – our new PBS Series.
    “Science Nation” – Three years and counting of Science for the People.
    Blog Twitter Facebook
  • Oliver Peters
    January 18, 2013 at 12:23 am
    Thanks. Lots of good info.
    – Oliver
    Orlando, FL
