Premiere Pro and Livetype
Hi there,
basically having massive annoyance with CS5 Prem Pro and any text graphic going into it. I’m a little confused to say the least! I have been searching around for ages but I cannot find a solution on the forums or elsewhere.
SO for starters I have a graphic from After Effects I am putting into Premiere Pro. Now the settings I had are identical and I get pixelation in PP but not in AE. I try to adjust settings, and I get variations of pixelation but it always is pixelated. SO I stick to identical settings that are one of two:
1024 x 576 Square Pixels DV PAL
Or
720 x 576 (1.46) DV PAL
Neither one leaves me with a clean image. Background layers are fine – JUST the fonts are getting pixelated.
The same issue is occurring on Livetype .mov files exported with the correct settings. No matter what I’ve tried I always end up back in the same place – with pixelated text.
Now I saw mentioned somewhere that pure black and white can cause issues with DV Pal when it comes to fonts? Is this true?
I am seriously at my wits end for what I can do to resolve this because it is VERY physically noticeable and yet I’ve never had this issue before having used similar graphics on CS3 many times before to no issue.
Any help?
Chris Bayliss
