Activity › Forums › Adobe Premiere Pro › Premiere pro and HDV Problem
  • Premiere pro and HDV Problem
    Posted by Ltchady on July 23, 2007 at 12:28 am
    i am working with premiere pro 2 2 years ago , when capturing i used a canon mvx 150 i dv cam but now i bought the sony hdr-hc5e HDV 1080i but it won t work with PP2 , i can only control the camera capture sound but not video , anybody knows why ?
    i tried to chage the capture settings from capture windows but it won’t works . there are three type DV , HD , HDV , i tried all .
    any help please , thank you
    Mike Velte replied 19 years, 2 months ago 4 Members · 3 Replies
  • Steven L. gotz
    July 23, 2007 at 1:01 am
    Did you set the capture to Sony / Standard ?
  • Blast1
    July 23, 2007 at 4:52 am
    Are you refering to that you can’t see video in the capture window? If so this is normal just a legend that says you are capturing appears in a black window.
  • Mike Velte
    July 23, 2007 at 11:34 am
    Make sure “Down convert to DV” is turned off in the camera.
