Activity › Forums › Adobe Premiere Pro › Premiere Pro And Clarity
  • Premiere Pro And Clarity
    Posted by Max Jasso on August 18, 2009 at 5:33 pm
    I videotaped outside, had wonderful clarity and even looked HD. Problem is, that when I started to edit in Premiere Pro, the clarity was not there, this ‘was’ after rendering. Is there anyhting I can do to maintain the clarity from the videotape. Not having the clarity really takes away from the impact of this film. Thanks for any and all help,…..Max
    Vince Becquiot replied 17 years, 1 month ago 2 Members · 1 Reply
  • Vince Becquiot
    August 18, 2009 at 7:16 pm
    Clarity and compression are closely related.
    What are you using for your output settings?
    Are you de-interlacing? That process will soften your image quite a bit.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
