Activity Forums Adobe Premiere Pro Premiere Pro AJA Kona Output to Monitor
  • Premiere Pro AJA Kona Output to Monitor
    Posted by Eddie Kesler on June 24, 2011 at 4:27 pm
    How do you set PP 5.0 to playback through my broadcast monitors with my AJA Kona 3 card? I’ve installed the drivers and it shows up under Player Settings (which I set it to). But it doesn’t show up under Playback settings in the Program window.
    Eddie
    https://www.jamedit.com
    Chris Knight replied 15 years, 2 months ago 2 Members · 1 Reply
  • Chris Knight
    June 24, 2011 at 4:33 pm
    You have to load an AJA sequence preset, then load a clip and see if it plays (even in the source window). If not, then go to playback settings (under project menu) and select the correct video output (it usually defaults to SDI). Depending on the driver version (I’ve been using AJA boards with Premier since CS3), I’ve sometimes had to go into Machina to set things there first.
