Activity › Forums › Adobe Premiere Pro › premiere pro 5.5 won’t playback more than 1 second
  • premiere pro 5.5 won’t playback more than 1 second
    Posted by Darin Morash on March 8, 2013 at 10:53 pm
    Hi there I’m a FCP 7 convert, I just made the switch to premiere 5.5, mac pro 8gb ram 2×2.4 quad core. OS is 10.6 I xmled my fcp to premiere no problem. everything transferred fine, but now that i try to play it back is just stalls after a second or so . I did some digging around and i found that I could delete the com.apple.audio.AggregateDevices.plist file, but it does not show up on my computer, I got our I.T guys to log into the computer on the administrator account, and not there either. I also found a solution to change the audio playback from our Kona card to system input/output
    but I get this error:
    /Volumes/BuildDisk/builds/ring064/shared/adobe/MediaCore/MediaLayer/AudioSupport/Make/Mac/../../Src/Mac/CireAudioHost.cpp-560
    Any other thoughts? There is no money in our budget to upgrade to CS 6 or my OS
    Darin Morash replied 13 years, 6 months ago 2 Members · 3 Replies
  • Tero Ahlfors
    March 9, 2013 at 11:58 am
    Do you have a some sort of “stop playback if you get dropped frames”-option on with your I/O. I had a similar thing with our Blackmagic I/O.
  • Darin Morash
    March 11, 2013 at 2:15 pm
    As far as I know it doesn’t. Although, as soon as click on the control panel for it, it crashes. So it could be causing a problem. I think I will spend today reinstalling.
  • Darin Morash
    March 11, 2013 at 3:49 pm
    So riddle me this….
    We logged in as the administrator and it worked fine, so then re logged in on my account and it started working again.
