Activity Forums Adobe Premiere Pro Premiere Pro 4k sequence bright rectangle
  • Premiere Pro 4k sequence bright rectangle
    Posted by Bobby Kay on April 2, 2020 at 2:59 pm
    Hi this is my first time doing a 4k sequence. I have 4k and 1080p footage. I actually started in a 1080p sequence, then client said they require it in 4k. I tried duplicating the sequence and changing the settings to 4k, and I tried making a new 4k sequence and copying the edit into that.
    Both resulted with a bright rectangle center frame, like the exposure is cranked up in a rectangle shape. I assumed it was some kind of 1080p crop guide, but even when exported it’s there. I have a feeling it’s a simple fix, but not knowing what it is, I don’t know what to search for.
    It’s not allowing me to upload a screenshot, sorry. Thanks for your help.
    Paul Neumann replied 6 years, 5 months ago 2 Members · 3 Replies
  • Paul Neumann
    April 2, 2020 at 3:08 pm
    It might be an improperly sized adjustment layer or mask.
  • Bobby Kay
    April 2, 2020 at 3:54 pm
    You sir….are correct. I didn’t scale the adjustment layer. Dumb oversight. Thank you!
  • Paul Neumann
    April 2, 2020 at 6:35 pm
    Everyone has done it. If they haven’t then they’re not really trying.
