Activity › Forums › Adobe Premiere Pro › Premiere Pro 2023 just isn’t exporting.
  • Premiere Pro 2023 just isn’t exporting.
    Posted by Nick Hill on August 4, 2023 at 11:41 am
    Haven’t used PPro for a couple of weeks. Went back into a project to re-export something, and the export function had stopped working: Ctrl+M, File > Export > Media or going to the Export tab all just gave a grey screen with the spinner which sat there doing nothing.
    I tried opening up a couple of other projects which were working fine, and exporting didn’t work with those either. (It had finished creating all peak files etc.) I could *play back* the timeline with no problems or glitching, which is
    weird; mostly, issues like this also affect playback in my
    experience.
    Uninstalled PPro with CCCleaner & reinstalled. Restarted the machine. No dice.
    Then I updated my gpu drivers. Suddenly, the export function worked. Great! I exported that timeline (1 of 2 I needed to export), but… when I went into the second timeline, and tried to export that, I’m back to export not working. Spinner. Nothing.
    I’ve deleted cache, prefs, etc with Alt+Shift+startup. What’s going on? Is there anything else I can do to make sure this doesn’t happen again?
    System: Threadripper 3960X, 128GB RAM, RTX 4090 24GB, Windows 11 Pro. Have updated everything I can think of.
    Hector Vera replied 3 years, 1 month ago 2 Members · 1 Reply
  • Hector Vera
    August 7, 2023 at 9:08 pm
    That export issue you are having seems to be some sort of glitch and if you even reinstalled it after uninstalling it, it still gives this issue huh? The specs you have on your PC is more than enough for exporting. Even my PC that is faaaaar inferior to yours was able to export in Premiere Pro but I have experienced issues like this before once in a while. There could be an unwanted .dll file or some malware that could be preventing you from export it. You may want to first use an anti-virus software to see if it detects any strange files that you have not realized that is giving you this glitch. Question, does it give you an error message? If it does, you should start researching on google on what that error message does exactly.
