Activity › Forums › Adobe Premiere Pro › Premiere Pro 2022 – Can 2 Videos Be Viewed and Edited Simultaneously?
  • Premiere Pro 2022 – Can 2 Videos Be Viewed and Edited Simultaneously?
    Posted by Keith Dieter on February 17, 2023 at 1:46 pm
    Hi everyone.
    I have two videos of the same game footage. The original is an hour and ten minutes long, with full play footage and sound.
    The second is about 50 minutes long, cut down from the original footage. It was used for a streaming broadcast, but had no sound on the output.
    I’d like to be able to compare the two videos side-by-side in Premiere, and cut down the original to match the cuts made for the streamed video. From there, I will convert the edited original to an MP3 and add it to the streamed video, which will hopefully fix the streamed video’s audio problems.
    Is there a way to produce a split-screen to see both videos at once, so I can determine where to make the cuts?
    Thanks in advance for any help.
    –Keith
    Santanu Bhattacharjee replied 3 years, 6 months ago 3 Members · 2 Replies
  • Eric Santiago
    February 17, 2023 at 3:15 pm
    Have you tried Multi-Cam?
  • Santanu Bhattacharjee
    March 5, 2023 at 6:03 pm
    I haven’t tried this. But may work if you have the same audio in both the footage. Put both footage one above other on the timeline. Scene detect and cut the shorter video. Then, do a sync video based on audio. The clips from the shorter video will align to the times of longer one. Now you may cut the longer video and remove the unwanted clips.
    Santanu – http://www.santanu.biz
