Activity Forums Adobe Premiere Pro Premiere Pro 2015 Choppy Renders
  • Premiere Pro 2015 Choppy Renders
    Posted by Ritchie Mellor on September 11, 2015 at 8:47 am
    HI guys, am rendering out some drone foorage from PP 2015 and the export seems jumpy to me.
    https://youtu.be/0Jx5HLU8RBs
    the intro is done in AE with Element3D and looks smooth, but the footage just isn’t.
    The the footage was recorded with the DJI Inspire1, 1920×1080 at 29.97, my sequence is 29.97, and then output using the export within PP with the YouTube 1080p 29.97 preset.
    Before beinging into PP I run the footage through Mercalli v4 using the glidecam setting (all defaults) then output with the medium render setting. Only just remembered that part as I write this, so going to try and replace the footage with the original files, to see if it makes a difference, but it hasn’t on other test projects.
    Tero Ahlfors replied 10 years, 12 months ago 2 Members · 9 Replies
  • 9 Replies
  • Tero Ahlfors
    September 11, 2015 at 12:25 pm
    If the framerate has stayed the same then I would suspect the stabilization and/or the original footage. Some of the bits in the footage might be impossible to stabilize smoothly and there might be bigger bumps that just look weird when it’s stabilized.
  • Ritchie Mellor
    September 11, 2015 at 12:41 pm
    Thanks for the reply. It’s more that it looks to me like the frames are generally jumping or skipping. I’m not concerned about the smoothness of the actual camera moves, as it was some early footage we did and that is main pilot error!
    It just doesn’t look a smooth as it should, jittery may be a better term.
    Will be double checking my frame rates though.
  • Ritchie Mellor
    September 11, 2015 at 2:25 pm
    Have swapped footage and it’s still jerky like in the video, checked frame rate on source, stabilised and sequence. Also done the export through AME. Any ideas??
  • Ritchie Mellor
    September 11, 2015 at 3:46 pm
    okay, so I have rendered just a source clip and the results are smooth as I want them, so definitely something funky is happening in Premiere. I sped up the footage using Speed/Duration, but the results are the same, so not that.
    My export settings are
    Width: 1920
    Height: 1080
    FR: 29.97
    Field: Progressive
    Aspect: Square
    TV Standard: Based On Source
    Profile: High
    Level: 4.2
    Render At Max Depth: Off
    Bitrate: VBR, 2 Pass
    TBM: 16
    MBM: 16
    Key Frame Distance: Off
    Use Max Render Quality: Off
    Use Previews: Off
    Use Frame Blending: Off
  • Ritchie Mellor
    September 11, 2015 at 4:34 pm
    Okay, so I have used Media Browser to find one of the source clips and dragged that into the timeline to create a sequence, exported with previous settings and its smooth as I want!
    Checked Sequence settings for both this and y original and they are identical! So NOW I’m even more confused!
  • Ritchie Mellor
    September 25, 2015 at 5:23 pm
    So, still messing around with this, and it seems to be linked to the speed / duration and time remapping options. Everything is fine until I change the speed of a clip and then that clip is choppy. I have set a clip at 120%, reverse field order, processing with None, Always Delinterlace and Remove Flicker, no difference. I have tried Render and Replacing, Render In/Out, just not making a difference, but if I chance the speed back to 100%, its perfect again, so that is definitely the issue. Same issue if using GPU or Software Renderer. Using Frame Blend does improve things, but still looks funky.
  • Tero Ahlfors
    September 25, 2015 at 8:04 pm
    [Ritchie Mellor] “reverse field order, processing with None, Always Delinterlace and Remove Flicker, no difference.”
    I have no idea why you would even do this.
    [Ritchie Mellor] “Using Frame Blend does improve things, but still looks funky.”
    Then the issue is with the footage and the fact that you’re trying to do too much to it and it breaks. You could try Twixtor or the optical flow time warp that AE has.
  • Ritchie Mellor
    September 25, 2015 at 8:32 pm
    Thanks for the response.
    I am at a point of trying ANYTHING! I read about reversing speed caused an issue, so was having a play.
    Even just brining footage in and altering speed does it.
    Will just process the speed part in AE, but really want to know why this is happening.
  • Tero Ahlfors
    September 26, 2015 at 6:46 am
    [Ritchie Mellor] “but really want to know why this is happening.”
    You are changing the speed of footage that doesn’t look good when you do it.
