Activity Forums Adobe Premiere Pro Premiere Pro 2014 – No Audio Scrubbing
  • Premiere Pro 2014 – No Audio Scrubbing
    Posted by Cliff Stephenson on August 2, 2014 at 7:05 pm
    Running 2009 Mac Pro Mavericks. Blackmagic card with the latest desktop 10.1.2.
    Updated to PP 2014 and I now have no frame by frame scrubbing (Was running the original version and now the updated release, no go on either). I have scrubbing checked in the audio settings, but I get no audio during FxF or shuttle. It still works totally fine in PP7, but not in 2014. This makes using it to edit IMPOSSIBLE!!!! I can’t be the only one, can I?
    Is this an Adobe thing? A Blackmagic thing? Is it something on my end that I’m not aware of? This happened with PP7, but it eventually got fixed. Just don’t understand how it still works with PP6&7, but not 2014.
    Thanks in advance…
    Christopher Burke replied 12 years ago 3 Members · 3 Replies
  • Mike Cohen
    August 24, 2014 at 11:04 pm
    I’m using Premiere CC on windows, and what I have found is if you scrub using the mouse and drag within the time part of the sequence header (the part with the little tick marks) the audio that plays is not teh audio you would expect – I am not sure where it is coming from.
    But if you move the mouse cursor down so that you have the double arrow that hugs the current time indicator, you get the correct audio.
    Using JKL I get the correct audio
    Mike Cohen
  • Christopher Burke
    September 17, 2014 at 2:07 pm
    Cliff — I have the same problem on a 2012 MacPro, on Mavericks with Blackmagic Desktop Video 10.1.4 using a Blackmagic PCIe MiniMonitor.
    I can get scrubbing to work by just running audio through internal speakers or direct line out of the Mac … but of course that defeats the purpose of Blackmagic playback, doesn’t it?
    Anyone with a solution? Looked on Blackmagic’s forums but can’t find anything.
  • Christopher Burke
    September 17, 2014 at 2:11 pm
    Update — toggled settings in a few different combinations based on this post:
    https://forums.creativecow.net/readpost/124/884764
    and now it works. Make sure all the audio mapping/outputs/playback are set to Blackmagic playback, and that your external video playback is enabled via Blackmagic as well.
