Activity › Forums › AJA Video Systems › Premiere Pro 2.0 “Xena NATIVE HD Support”
Posted by John Richard on May 9, 2006 at 11:40 pmReading thru APro2.O lit there is a statement that claims there is native support of the Xena HD …. I thought you needed ProspectHD to ingest/capture and edit HD.
A little confused…
Wally Tham replied 20 years, 3 months ago 4 Members · 5 Replies -
Aja Sales department
May 10, 2006 at 1:58 amHi,
XENA HS is a dual rate SD and HD card, that has Native support in Adobe Premiere Pro 2.0. This means that for any uncompressed SD or HD video I/O, the HS support is integrated directly within PP2.0, without the need for additional software setups, etc. This native support was co-developed by Adobe and AJA.
https://www.aja.com/html/products_windows_xena_HS.html
Cineform’s ProspectHD also works on the XENA HS card, for use of their very efficient and clean compressed HD codec, to achieve more RT and lower disk usage while still getting on-line quality HD video. Cineform has also recently qualified the XENA LH card for use with Prospect HD.
https://www.cineform.com/products/ProspectHD.htm
The XENA LH, XENA LS, and the XENA 2K whith the soon to be released v2 software (available May 31) have “homegrown” AJA-built PP2.0 support, as well unique support for After Effects, Photoshop, Eyeon Fusion, and Autodesk Combustion. This new support gives you unparalleled uncompressed file format support (QUICKTIME, AVI, DPX, CINEON, TGA, TIFF, BMP, on LH and 2K cards, and QUICKTIME, AVI, TGA, TIFF, BMP, on LS), allowing even mixing and matching of different file formats on one timeline, with RT color effects (LH, 2K) and much more.
https://www.aja.com/html/products_windows_xena_2K.html
https://www.aja.com/html/products_windows_xena_LHe.html
https://www.aja.com/html/products_windows_xena_LSe.htmlIf you need addional information, please feel free to contact AJA.
Thank you,
AJA Video Systems
(530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Tim Kolb
May 20, 2006 at 7:21 pmHi LightPrism,
Actually PPro v2 does have project settings right out of the box for “Adobe HDV” native (editing MPEGTS, FW I/O) and what they call “Adobe HD-SDI”. The Adobe HD-SDI (and SD-SDI) settings are designed to work with a Xena HS card as AJA Sales mentions…
I have a Xena LH and with the released drivers (which have AE and Photoshop support built in, though they will look for AE v6.5, so you’ll have to force them or drag them into the proper plug in folder for AE 7)…you can get the board to work with Ppro’s native SDI HD/SD modes if you run Machina (Pronounced “Mach”-in-a like the speed of sound, not like “machine” as I was informed…) you can get output from PPro v2, but the upcoming drivers will make it a direct relationship with AJA project settings.
There are always more features I’d like to see between CineForm and AJA beyond just I/O, but we need to give it some time as obviously both products are sophisticated and optimized in their own right at the moment…
…time will tell, but I think he possibilities are tantalizing…
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
John Richard
May 21, 2006 at 1:33 pmThanks Tim for the clarifications. So the Mach(k)ina is basically the capture software in the current version and the potential for PPro2 capture with upcoming driver release, right? Look forward to hearing about the functionality improvements of the new upcoming drivers for the LH/e. Building a new box shortly and am leaning toward the Xena LHe as it appears to have the best capability to price ratio for what we’re looking for:
-HDV editing Canon H1 24f, 30f, 60i
-SDI HD/SD ingest and edit off the Canon H1 – using Prospect HD (Ingest level)I only wished there was a way to then use the ingested files in Edius and their HQ codec as we’ve been quite happy with the speed/stability of Edius. We stopped AP 6.5 and will have to go thru the learning curve of PremPro … but with the nice integration of all the Adobe progs now, it’s something I need to do anyway.
Looking into a machine that has both a XenaLHe and Canopus NX card with separate profiles…
May 21, 2006 at 3:59 pmHi,
Machina is a stand-alone capture/playback to/from VTR/disk application, for users of programs that do not have these abilities built-in (graphics apps, etc.). The upcoming XENA v2 software offers powerful PP2.0 capabilties, which of course include capture, etc. within Premiere. v2 will be available for download May 31 at http://www.aja.com.
Thank you,
AJA Video Systems
(800) 251-4224 US
sales@aja.com -
Wally Tham
June 3, 2006 at 3:06 amDoes Xena LH cards allow capture to and editing of DVCPRO HD Codec in Premiere Pro 2.0?
