Activity › Forums › Adobe Premiere Pro › Premiere Pro 2.0 Stills magnification
  • Premiere Pro 2.0 Stills magnification
    Posted by Jerry Littlejohn on April 7, 2012 at 11:10 pm
    I am importing many photographic stills. The source viewer shows the images as the correct size, that is, full-frame. When I drag the stills to the timeline, the image is the correct size on the timeline but the program monitor shows the image greatly magnified (the middle 10+- of the still image). Playing the timeline reveals that same program monitor magnification. Why? What can a man do? Jerry
    Ann Bens replied 14 years, 5 months ago 5 Members · 5 Replies
  • Tom Daigon
    April 8, 2012 at 12:08 am
    How about upgrading to the most recent version of Premier? 😀
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Angelo Lorenzo
    April 8, 2012 at 1:25 am
    Sounds like the still is larger than your video frame. PPro 2.0 may or may not have this but rightclick the image in the timeline and select “Scale to frame size”, otherwise you’ll have to manually adjust the scale of the image – Position, scale, and opacity should be available under the “effects control” panel.
  • Ann Bens
    April 8, 2012 at 9:44 am
    Under Preferences/General you will find a checkbox: default scale to frame size.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Alex Udell
    April 8, 2012 at 11:37 am
    So the resolution of your stills does not match the resolution of your editing sequence.
    the source viewer will always show images at actual size.
    the program monitor will always lock to what the sequence is set to.
    so prior to importing your still photos into your project, if you set the preference Ann notes in the previous thread….
    then your stills will scale to the size of your sequence placed on the timeline. (note that your effects controls will still say 100%)
    this may or may not be what you want….
    and big question is…what are you trying to deliver? because that dictates how you should set your sequence up initially…
  • Ann Bens
    April 8, 2012 at 12:39 pm
    Forgot to mention: when checking to default scale to frame size, in Pro2 one has to reimport all the stills.
    Otherwise it wont work.
