Activity Forums Adobe Premiere Pro Premiere Pro 2.0 Slowness. It’s that Normal??
  • Premiere Pro 2.0 Slowness. It’s that Normal??
    Posted by Bernardo on March 22, 2006 at 6:09 pm
    Hi guys.
    Just to check if someone it’s having the same problem…
    I did install Premiere Pro 2.0 last night.
    I did a test with the same color correction effect on both versions; 1.5.1 and the new 2.0.
    Well, the render time on the new version (2.0) it’s 3X slower than the previous one..
    1- PPro v 1.5.1 render time = 2 minutes (1″ clip)
    2- PPro v 2.0 render time = 6 minutes (1″ clip)(not using maximum bit depth render)
    This’s normal?
    I’m running DL Extreme PCIe with Premiere Pro on a certified Blackmagic System:
    INTEL PENTIUM DUAL CORE
    Asus P5WD2 Premium
    Intel Pentium D Dual Core 830
    3 SATA disks with 8MB cache using onboard RAID
    nVidia GeForce NX6600
    4GB DDR2 800 RAM (CORSAIR TWIN2X2048-6400PRO)
    535 watt Power supply (24 pin) – Enermax
    Thanks in advance.
    Bernardo
    Rio de Janeiro – Brasil
    Bernardo replied 20 years, 6 months ago 3 Members · 4 Replies
  • Aanarav Sareen
    March 22, 2006 at 8:16 pm
    Which color corrector did you use in Premiere Pro 2.0?
  • Bernie
    March 22, 2006 at 10:57 pm
    3-way color corrector
    curves
    *no secondary correction…
    thanks
  • Aanarav Sareen
    March 22, 2006 at 11:22 pm
    Hmm…I will give it a shot tonight and post back.
  • Bernardo
    March 23, 2006 at 4:50 pm
    Thanks Aanarav.
