Activity › Forums › Adobe Premiere Pro › Premiere Pro 2.0 keyframes, timeline
  • Premiere Pro 2.0 keyframes, timeline
    Posted by Jerry Littlejohn on March 25, 2011 at 7:53 pm
    Thanks to Ann Bens. I have not been doing this very long and cannot engage the pen tool under window/tools. I want to set keyframes on an audio channel to lower volume. Ann suggetsed using a “press add/remove keyframes” but I cannot figure out how to that. I used to use the backslash key but now that doesn’t work. The track is set to Track Volume.
    I have finished a 15-min all-photographic still project (225 stills). The timeline does not load all of the images, so during playback and burning most transitions are gone because the images are not laoaded on the timeline. Where the images are loaded they play fine but Adobe is not filling the timeline totally, making impossible to play or burn correctly. Any ideas? Not had this problem befoire.
    Jerry
    Ann Bens replied 15 years, 6 months ago 2 Members · 1 Reply
  • Ann Bens
    March 25, 2011 at 8:23 pm
    For Premiere 2 you need to make the stills the same size as the project if you have not done this. 225 Stills are a awfull lot to load especially if the are full resolution.
    If you did make the stills the same size and still having trouble burning dvd make a dv-avi first, import this into a new seqence and burn to this sequence to dvd.
    The backslash key for me has alway been zoom to sequence.
