Activity Forums Adobe Premiere Pro Premiere Pro 2.0 hangs
  • Premiere Pro 2.0 hangs
    Posted by Timothy Eng on July 25, 2007 at 4:55 am
    Hi All,
    I have been having a consistent problem every time I use Premiere. That is it hangs for a period of 10-30 seconds every time I start it, or when ever I switch between 2 programs (such as switching from after effects to premiere). After the hang it works as per usual, but it is having major impacts on my workflow as I often work between two Adobe programs at a time. I am only editing DV footage and after effects renders, so I can’t see that I am pushing the computer past its limits.
    I didn’t have this problem when I was using Premiere Pro 1.5 – Only since moving to 2.0.
    Here is the configuration of my computer:
    P4 3.2 Ghz Processor w / HT
    3GB of RAM (Virtual memory set to 3801MB as recommended by windows)
    1 x 300GB operating drive
    2 x 300GB video drives in a mirrored RAID array
    ATI Radeon 9550 Graphics card
    Windows XP Professional
    Standard OHCI firewire card
    I should be receiving Production Studio CS3 soon (As I was elegible for the free post-announce upgrade) so will no doubt have to perform a fresh install of everything then.
    Any help guys would be really appreciated.
    Tim.
    Steven L. gotz replied 19 years, 2 months ago 2 Members · 3 Replies
  • Steven L. gotz
    July 25, 2007 at 3:58 pm
    It happens to me too. It has to do with memory swapping I think, which is why I am glad I have a 10K rpm system drive. And I am thinking of going to 15K rpm.
    Steven
    https://www.stevengotz.com
  • Timothy Eng
    July 26, 2007 at 12:56 am
    Thanks for your imput Steve,
    But surely there must be another fix for the solution than to get 15K RPM system drives. Last time I read the specs on Premiere I can’t remember reading the need for it.
    And I’d be really surprised if everyone out there without 15K RPM or even 10K RPM drives was having the same problem.
  • Steven L. gotz
    July 26, 2007 at 3:24 am
    It depends on the type of media, the amount of media, etc.
    Steven
