Activity › Forums › Adobe Premiere Pro › Premiere Pro 2 bootup
Baz Leffler
November 27, 2006 at 11:10 pmPhil said:
“I went into my audio codecs and selected the emulator codec once again. Now the program continues to boot up without any problem”Yes Phil… thats what I found as mentioned in my previous post…
“What I did was open the control panel and disable the audio codecs, confirm PPro would open all the way and the while PPro was running go and re-enable the codecs. After that PPro would open normally everytime. Didn’t make sense then, still doesn’t make sense now; but nevertheless I blamed it on Bill Gates.”
See you have confirmed it wasn’t something I did stupidly!
Baz
Janice Demille
May 30, 2007 at 5:29 pmHello, I am having the same problem. Premiere Pro was working fine on this computer. I opened a project I had stored on an external hard drive and it shut down. Since then I have not been able to get it to work for me. I have disabled all of the audio codec and it still shuts down on me. The external hard drive is not connected any longer. I have also deleted the prefs file and started the application holding the shift key. It shuts down when the Write_On.aex loads.
Does anyone have an idea of what I can try? I am out of town for 4 weeks and had planned to catch up on my editing. My software is at home…
thanks
