Activity › Forums › Adobe Premiere Pro › Premiere Pro 2 and Windows Remote Desktop
Posted by Umvidguy on September 10, 2007 at 12:37 pmHas anyone successfully used Windows Remote Desktop from a home computer to access Premiere Pro 2 on an office computer?
If so, was it through an unusual configuration of Remote Desktop?Adam Kortepeter replied 16 years, 5 months ago 5 Members · 4 Replies -
Aanarav Sareen
September 10, 2007 at 10:52 pmI wouldn’t even attempt it, just because the experience is going to be horrible. Also, not many internet connections can handle that kind of bandwidth, so editing remotely may lead to a lot of mistakes.
– Aanarav
Aanarav Sareen
premiere@asvideoproductions.com
https://www.asvideoproductions.com/techtalk -
Lyn Norstad
September 11, 2007 at 12:45 amThe connection bandwidth is not really much of a problem (if you have DSL or Cable). All you’re doing remotely is controlling the editing system … all the data is local to that system.
I run Premiere Pro (both CS2 and CS3) on office systems from home routinely. I use a program called LogMeIn (the free version). I also use it to take control of client computers and do the same thing remotely for diagnostic purposes.
LogMeIn does reduce the color space, however, so you’re not going to be able to accurately handle image quality issues. It certainly works for rough cuts tho … as long as you don’t mind a slight “lag” in responsiveness.
Regards,
Lyn Norstad
Chicagoland, USACo-host of CreativeCOW forums:
Discrete Edit*ors
Matrox Video Systems
Leitch dpsVelocity -
Zac Lam
September 14, 2007 at 5:21 pmYes, I do this from time to time. However, in the Options, in the Local Resources tab, you should set Remote computer sound to “Leave at remote computer”.
Adam Kortepeter
March 25, 2010 at 4:24 pmThe “Leave at remote computer” setting works to get video playback, but now there is no audio.
Does anyone know how to use an RDC with Premiere for both audio and video, or is there a more current thread on this subject? I am using Premiere CS4 via remote desktop and having similar issues.
Adam Kortepeter
User Experience Analyst
